    ENO Double/Double
    ENO has a "double/double" crankset: http://www.whiteind.com/ENO_web/eno-index.html
    IN - 35/19 - hit the mountain
    OUT - 38/16 - around town
    I'm considering this for a 29" SS MTB since I will be riding a mixture of long hills and flat areas. It has a double chainrink up front (35/38) and a double freewheel (16/19).
    The advantage is that you can change gearing without flipping the wheel as in the case with a flip/flop hub.
    Any opinions about this type of setup?
    Cubicle Fugitive
    Reputation: czardonic's Avatar
    I've messed around with 3x1 and 2x1 set-ups on my CX bike and ultimately settled on a single speed 39x17 for all terrain. Its kind of a grind on really steep hills, and a little spinny on long flats, but I still prefer this set-up to chain slap, cranky derailleurs and shifters cluttering up my bike. I was quite surprised at how quickly I adapted to riding 37:17/700C on stuff I thought I needed 32:18/26" to clear.
    I'd suggest at least trying a single before spending that much on the double ENO stuff.
    Reputation: oldskoolboarder's Avatar
    I like my double double animal style
    [I ran a 2x2 for awhile . No tensioner, just picked 2 combinations of ring and cog that had the same total tooth count and happened to fit my chain stay length without a tensioner. To switch from one gear to the other I flipped the bike over, lossened the rear wheel and shifted the chain by hand. It worked, but ultimatley I went to a 1x2 using a derailleur for a tensioner and shifting between the 2 cogs by turning the barrel adjuster on the derailleur. You need a short peice of brake cable with the head in the barrel adjuster and the other end clamped on the derailleur. More convenient and cleaner to do the shifting.
  1. New and Improved ENO 32 tooth Chainrings
    By Objectionable Material in forum Singlespeed
    Last Post: 06-10-2005, 01:38 PM
  2. ENO disc hubs... confused and no pictures
    By SSlowTwitch in forum Singlespeed
    Last Post: 04-18-2005, 09:07 PM
  3. ENO vs. 'The tire'
    By Adrian in forum Singlespeed
    Last Post: 02-21-2005, 03:50 PM
  4. ENO, who woulda thought?!?
    By AlloyNipples in forum Singlespeed
    Last Post: 10-25-2004, 10:33 AM
  5. yet another satisfied ENO customer...
    By chuffer in forum Singlespeed
    Last Post: 09-15-2004, 07:47 AM
