Results 1 to 10 of 10
    Eno or chain tensioner?
    Going to be using an old MTB frame I have with Vertical drop outs.
    I will be building a new wheelset for this bike regardless of above Choice.
    My understanding if I choose an ENO hub is obviously won't need the chain tensioner, so possibly quieter, more efficient ride, aesthetically pleasing.
    Are there any advantages to using a chain tensioner? Other than cost?
    www.mtbiker.ca
    My Rides:
    FSR XC -R7 Platinum - SRAM X7 (26.5lbs)
    Cervelo SLC - SRAM Rival - Reynolds DV46T (16.25 lbs)
    Reputation: EvilScience's Avatar
    Eno
    If you're building a new wheelset regardless, go ENO. I started by converting my old hardtail with a tensioner, and it was fine. But, when I tacoed the rear wheel and put a replacement on with an ENO eccentric hub - what a difference.
    Less friction, no noise, and yeah - it looks much cleaner.
    Besides, those hubs look bombproof - probably outlive the bike...
    Changes in axel position of the ENO may require slight brake adjustments that may not be needed with a tensioner. Not too big of a deal though.
    Reputation: marks_bike's Avatar
    I agree, if you're building a wheelset anyway go with the ENO. Plus White ind. freewheels are super sweet.
    bump and grind
    Reputation: cobym2's Avatar
    Apr 2005
    If money is not a consideration, go with the ENO eccentric hub. Definitely bling, definitely bombproof. Cleaner lines.
    I, however, prefer the tensioner since I like swapping out and switching wheels and cogs to suit the ride (mud set to dry set to road set). The tensioner is just a lot less hassle to work with. Plus, its dirt cheap.
    Reputation: anvil_den's Avatar
    Nov 2007
    ENO ecc hub -- for the clean line look. Having a tensioner was just a little too "deraileur looking", something I wanted to get away from when building up my ss.
    Performance wise- nothing to complain about. Oh the WI hubs- they just keep spinning and spinning and.......
    Great, thanks guys.
    Hmmm.. with disc mount or not now?
    The frame I'm using doesn't have disc tabs. But who knows, I might upgrade in the future.
    www.mtbiker.ca
    My Rides:
    Reputation: boomn's Avatar
    Quote Originally Posted by bbgobie
    Great, thanks guys.
    Why limit your possibilities, especially with a hub that should outlast your frame
    Yeah, thats what I'm afraid of. Enjoying SS so much I buy a whole new bike....
    www.mtbiker.ca
    My Rides:
    I'm pretty sure the ENO eccentric hub can be converted to a normal straight axle. So if you end up with a SS specific frame later down the road you can just convert it.
