Results 1 to 17 of 17
    Reputation: PnoyPride's Avatar
    May 2013
    Eccentric BB pinch bolts
    Hello single speeders. where can I purchase a pinch bolts for an eccentric BB? I have a 2013 specialized carve sl, theres nothing wrong with my current bolts but Im just wondering if I can change it to a titanium bolts or anything better than the stock bolts. Thanks in advance.
    1*14*29*2.1 & 1*1*29*2.4
    I'd stick with steel bolts for things needing cranking down hard.
    May 2013
    I agree. Where can I find these bolts?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by PnoyPride View Post
    This is not a place for ti or aluminum bolts. Stay with steel and deal with the extra 5-10g.
    Steel bolts can be found at most any hardware store, if you ever need replacements (very unlikely).
    mtbtires.com
    oh..so you want a spare set? Not sure what size you have but they are usually metric...take one out and take it to the local bolt supliers and see what they have. They'll have a range of head type and material types. Could even get stainless but probably better with high tensile steel. These shops are fairly common for trades people, usually in industrial areas. Should be able to find it in the local phone book. Like shiggy said, a hardware will have something, just depends on what choices you want
    May 2013
    Lowes, harbor freight tools and home depot dont have any of these bolts? I will check the local hardware stores. Thanks again guys.
    possibly...if they have a nuts and bolts section it is likely.
    Dec 1998
    ...there's nothing wrong with my current bolts...
    Waste of time.
    Go ride.
    mtbtires.com
    Nov 2012
    Quote Originally Posted by finch2 View Post
    Definitely not saying I disagree with sticking with steel, but I would definitely be careful about cranking down too hard. Recommended torque on this is only 8.9 nM (80 in-lbs)
    Also, not completely sure these are steel. If they are, they are awfully soft steel. I have already rounded one out. So definitely make sure you allen wrench is completely set before applying too much torque.
    Quote Originally Posted by mast3rof0 View Post
    Good point...never had an EBB. My sliders like to be torqued up, but wouldn't want to distort a BB. Some blue Loctite may help the wear...I'd say grease or antisieze normally but have no idea if these things work loose easily or not. Oh I see you are talking head rounding out...High tensile should be more resistant, stainless isn't great in this regard either
    Apr 2013
    Doubt anywhere local will carry Ti, and any fastener supply will carry in boxes of 100. Online would be your best bet, here is a pair (2) from Chain Reaction
    Nukeproof M6 Ti Bolt | Buy Online | ChainReactionCycles.com
    These bolts don't need to be super tight so Ti would probably be okay, but Ti is only .6 the weight of steel so you're basically saving the weight of 1 bolt for $20+...
    Stainless in a high Grade on the other hand can probably be found at your local Ace or OSH, Home Deposit and Lowes carry crap for these sort of bolts...
    By the way they are M6 x 35mm which may be hard to find and you'll have to pick up M6x40
    May 2013
    Quote Originally Posted by rideorange525 View Post
    Thank you for this. This is very helpful.
    Reputation: jetboy23's Avatar
    You can even go for colors from Pro Bolt USA .
    May 2013
    Quote Originally Posted by jetboy23 View Post
    What size is the pinch bolts from the EBB? Is it 35mm? Thank you for this colorful selection.
    Apr 2013
    My Carve SL was 35mm from the shoulder of the head to tip
    mnoutain bkie rdier
    Reputation: rydbyk's Avatar
    Quote Originally Posted by shiggy View Post
    Waste of time.
    Go ride.
    Agreed.
    May 2013
    Thanks for all your input.
  1. Replies: 9
    Last Post: 07-16-2012, 01:52 PM
  2. Replies: 1
    Last Post: 02-28-2012, 08:14 PM
  3. FYI: Shimano Hollowtech - Crank Arm Pinch Bolts.
    By ProjectDan35 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-05-2011, 07:00 AM
  4. Pinch flats
    By biopacebob1 in forum 29er Bikes
    Last Post: 04-22-2011, 11:00 AM
  5. XTR M960 Pinch bolts
    By Ridin'Dirty in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-13-2011, 06:46 PM
