Results 1 to 3 of 3
Thread: EBB standard
    EBB standard
    Is there a standard in EBB diameters? I am planning to build a SS frame next spring. While shopping for frame parts I saw several sizes (54 and 57 mm dia these being Haden and Everest). Since I want to be able to try something new later on (or when I kill my EBB) I need to have uniformity in sizing.
    If there is not a standard, what is the most commonly used size?
    Steelhead
    Reputation: shiggy's Avatar
    Dec 1998
    No "standard". I do not know what the sizes used are. I do know that the Bushnell Is different than most (or all) of the EBBs that use pinch bolts or set screws. I do not know the size of the C'dale expanding EBB either.
    My preference is the pinch bolt type (works best on a steel frame). Dead simple and it works. As long as the insert gives enough throw (~1/2") it works and should never need replacing. Phil Wood makes a great one and will do custom sizes, too.
    mtbtires.com
    ogarajef@luther.edu
    Reputation: 1strongone1's Avatar
    Quote Originally Posted by steelhead
    Steelhead
    If there is a standard this would be the closest.
    Standard Eccentric Body 68mm x 2.142” OD
    Taken from the Phil Wood web site.
    "RIDE IT LIKE YOU HATE IT"
  1. EBB help...
    By DSR in forum Singlespeed
    Last Post: 12-20-2004, 12:17 PM
  2. Why EBB?
    By dirtySSanchez in forum Singlespeed
    Last Post: 11-01-2004, 02:19 PM
  3. Bushnell EBB in Dean setscrew BB - an update
    By 52-16SS in forum Singlespeed
    Last Post: 10-04-2004, 01:58 PM
  4. DIY EBB Conversion Part 2 (longish)
    By Chequama Mama in forum Singlespeed
    Last Post: 09-09-2004, 11:06 AM
  5. Bushy EBB slippery?
    By xrmattaz in forum Singlespeed
    Last Post: 08-06-2004, 02:40 AM
