I'll preface this with saying I've never opened a hub, I don't really know how they work, though I could mount a pretty good series of guesses.
I got to thinking about this as I really only use 2 gears on my road bike, and I really like the simplicity [and looks] of a good singlespeed setup. I see those two-sided hubs around sometimes, though usually with one freewheel and one fixie setup. Would it be possible to have a drivetrain on each side, running differing gear ratios, and have some sort of toggle that you could switch between them ? One of the drivetrains would be engaged, the other would just spin free in both directions.
Or would one be better off just buying an internally-geared hub ?
I have the world's only dual drive full sus and can't think of a "toggle" solution, but I would be curious to see what smarter people than myself have to say about such weirdness.
I imagine there are a good number of possible ways you could accomplish this, but the main this is if any of them would be efficient, practical, and not too expensive. Past a certain point, and it's probably better to just get an internally-geared hub, I would think.
are there any advantages to running that set up or is it just for fun??
I've only read about a couple of different options to do this
first being a kickback two speed hub is i believe what it is called, basically an internally geared hub but you slightly backpedal to change the gears. no idea how the mechanical side of the works.
a little bit stranger is a hub that is one gear when pedaled forward and another when you pedal backwards. not sure what it was called or who made either of these but i know they exist or did at one time
You could also get a mountain drive by Schlumpf. Not cheap, but it would look clean with no need for a shifter on your handlebar. You shift gears by pushing your heel against the push-button on the crank arms.
Very cool idea/product, but that's about 3 times the price of my entire bike so far.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
