Results 1 to 3 of 3
    organically fed
    Reputation: w00t!'s Avatar
    Does there yet exist an EBB for square taper cranks?
    So, I've been out of the loop for the past couple years. The last I remember, the EBB for square taper cranks was just an e-balling, garage-machinist's promise.
    Did it ever happen?
    nothing to see here
    Reputation: Stevob's Avatar
    Given that you'd have to squeeze an eccentric, bearings and spindle inside a normal threaded BB shell, I'd say no. The best option is White Industries eccentric rear hub.
    I see hills.
    I want to climb them.
    May 2005
    Technically, any EBB other than the 2nd generation Niner EBB will work fine with a square taper bottom bracket. But I don't think that's what you meant. If you meant a combination EBB and bottom bracket to fit a standard frame and convert it to single speed, then Stevob has answered your question.
  1. migrating square taper cranks
    By goodmojo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2012, 03:55 PM
  2. Anyone still using Square Taper cranks?
    By Dion in forum General Discussion
    Last Post: 08-08-2011, 01:34 PM
  3. Why square taper cranks?
    By jeff smith in forum Singlespeed
    Last Post: 05-10-2011, 09:34 PM
  4. Square taper cranks to look for/avoid?
    By ddellisny in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-19-2011, 10:37 AM
  5. does the EBB for square-taper exist yet?
    By w00t! in forum Singlespeed
    Last Post: 01-27-2011, 02:09 PM
