Results 1 to 3 of 3
    Reputation: gthcarolina's Avatar
    Mar 2005
    Did I buy the wrong cog?
    I just purchased a Plazmatic 18 tooth "front-threaded" cog to go on the fixed side of my flip-flop hub. It threads on nicely and contributes to a good chainline but its base is wider than typical. There is no room to put a lock ring on the hub outside the cog. Does this spell disaster? Seems like the cog will only get tighter with use, unless I try to use the crank to stop the rear wheel when in fixed mode.
    germs, needles, milk, death, snakes, mushrooms, heights, crowds, elevators
    Yes, it spells disaster. It is probably for a trials bike with a crank freewheel, thus the cog does not need to have a lockring as you cannot apply backpressure. You need a lockring, or a ghetto fix, which may be permanent. Get a different cog. Try Surly. You can try machining yours down until you can get a lockring on.
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    rotafix it with red loctite and it won't back off. ever.
    to remove you'll need to heat it with a torch to about 150 degrees and then back it off with a chainwhip.
    or you could just buy a surly cog and lockring (or use a lockring you currently possess) and be done with it retaining the ability to remove it at will.
    "Knowledge is good." ~ Emil Faber
