Results 1 to 5 of 5
    Reputation: sean350's Avatar
    Custom handlebars, any ideas?
    I posted a couple of days ago about a custom Jones h-barish thing I wanted to have built. I'd like to do it on the cheap so I'd have it done in steel. Anyone had a custom steel handlebar made? How much did the builder do it for?
    This should be the link:
    http://forums.mtbr.com/showthread.ph...17465#poststop
    Thanks for any info!
    -Sean
    'r you some kinda ssissy?
    Reputation: ssissy's Avatar
    i'm making one
    i'm currently building a h-bar style handlebar. fillet brazed, straight gauge cromo. i'd charge about $100 for the job. i'm not "in business" at the moment. no liability insurance so its too risky. but its only two fillets and a couple feet of steel, so $100 seems about right.
    Reputation: noslogan's Avatar
    try this
    Find out what kind/s of aluminum and steel have been used for handlebars. AND dimensions/thickness. You could then give that info to a welder with a design of your own.
    Hey, I thought of it. I just haven't done it.
    Reputation: ATXSS's Avatar
    That design eliminates the spot where I have my v-brake levers mounted (on the extension in front of the bar.) What are you going to do about that?
    I thought of that...
    Quote Originally Posted by ATXSS
    The idea behind these bars is to approximate my track bike lo-pros, while adding the h-bar angled part, so I'd probably either put cyclocross-style top levers (which are pretty short), or just lengthen the rearward angled part a little more to give room for the brake lever clamp.
    -Sean
  1. Dos Niner or custom steel?
    By Swami Scott in forum Salsa
    Last Post: 05-20-2008, 02:07 PM
  2. 2nd KM or custom...seeking opinions
    By qtip in forum 29er Bikes
    Last Post: 02-16-2005, 01:01 PM
  3. custom sizeing
    By michel in forum Custom Builders & Other Manufacturers
    Last Post: 10-23-2004, 08:03 AM
  4. Ride quality; Custom steel VS Ti
    By Kam in forum Frame Building
    Last Post: 03-02-2004, 05:37 PM
  5. custom BREW and custom Wanta
    By ashwinearl in forum Custom Builders & Other Manufacturers
    Last Post: 01-30-2004, 05:10 PM
