Results 1 to 18 of 18
    Crank and Ring suggestion needed
    What are y'all using for cranks and rings? and where are you getting them?? I am converting my hardtail to a single speed and am just using the middle ring on my triple. I would like to upgrade to a singlespeed specific crank and ring. The rings I am finding are modified to ease shifting. This is not what I want/ need. Any help is appriciated. Thanks
    hand me the dice
    Reputation: TryAndStopMe's Avatar
    Turbines
    i'm running square taper raceface turbines with a spot brand chainring and guard. if you want truly singlespeed specific then you can't do any better than the white industries SS cranks:
    http://www.webcyclery.com/.docs/prod...t_details.html
    "pain is only a pulse...if you just stop feeling it"
    Reputation: ernesto_from_Wisconsin's Avatar
    Anything or....
    Quote Originally Posted by nmcculloch
    You can go for any SS specific ring (not ramped) to start out. Some of my bikes have that setup, a Spot ring, or a BMX ring. Or if you want to go in style, try this:
    https://www.webcyclery.com/.docs/pro...t_details.html
    Really, any crankset you have can be turned to a real SS specific beauty. SS is about improvisation.
    ali'i hua
    Reputation: SlowSSer's Avatar
    coupla options:
    jericho sufferrings (the non-xtr ones)
    spot rings and bashers
    blackspire DH rings (unpinned, unramped)
    Whiskey Tango Foxtrot
    Reputation: eSSq's Avatar
    raceface
    i just switched out a truvativ stylo teams for a raceface prodigy xc's on my santa cruz. the difference in stiffness of the rf cranks compared to the truvativs is mindblowing. plus, the rf's were really cheap at my lbs (www.thepathbikeshop.com).
    now i have to get another pair of rf cranks for my bianchi!
    "Mr. Britannica"
    Reputation: roadiegonebad's Avatar
    Turbines
    old skool w/no inner ring bolt mounts, square taper, Ebay.
    All you really need is a new unramped ring (Salsas are fine) and maybe some single chainring bolts/nuts. If you are going for the bling factor, then the sky's the limit.
    theHeadlessThompsonGunner
    Reputation: SDizzle's Avatar
    03 XT-752, with good results. They're hella stiff and strong. I run a 32 t Blackspire DS ring and a homemade bashguard. I had to have them replaced under warranty (which Shimano was really nice about, but slooow), and don't have a current pic, but here's what my interim set up was.
    <img src='http://gallery.consumerreview.com/webcrossing/images/IMG_0050(5).jpg'>
    "I've courted brain damage like some courtesan of darkness."
    -The Good Doctor
    Jabberwocky Jockey
    Reputation: Darkwing Duck's Avatar
    Garden variety XT splined crank
    with a Salsa chainring and bashguard. Salsa makes some bomb diggety chainrings without any form of shift aids. Cheap too. Got mine for $20 from Bikeman.
    Calling out from the Land of the Riding Hillbilly.
    www.vassagocycles.com
    www.ntmba.org
    My Blog
    Contrarian
    Reputation: AndyArmstrong's Avatar
    Middleburn UNO are nice:
    Not sure how readily they're available in the US but I bet John Atkins Cycles can ship them from the UK.
    Penis Goat!
    Reputation: GirchyGirchy's Avatar
    Here are my new SS cranks...completely new and untested, hence the studio portraiture photography. I went with the new Shimano LX cranks, model M572, from Jenson USA for $64. The matching BB was $19. I ditched the rings (they're on ebay as we speak, if anyone's interested) and ordered a 34t Salsa ring. I think they look great...my own little mini-Saint cranks.
    Cranks in unmolested condition:
    <img src="http://locker.uky.edu/~bcelme2/bike/cranks1">
    I was messing around with chainring placement, here it is mounted on the outside:
    <img src="http://locker.uky.edu/~bcelme2/bike/cranks3">
    And here's the 'ring mounted in the middle....looks pretty good too:
    <img src="http://locker.uky.edu/~bcelme2/bike/cranks2">
    blame me for missed rides
    Reputation: weather's Avatar
    Quote Originally Posted by AndyArmstrong
    speedgoat carries them, it's 180 bucks for sq taper arms only. major $$$
    Combat Wombat
    Reputation: BrianU's Avatar
    Like everyone else posted....
    Really no need for a ss specific crank. When I converted my GT Zaskar, I went with a FSA V Drive Extreme crank, a Salsa 34t ring and a RF bashguard. The RF bashguard gives it a really clean look. The FSA crank, although not as great looking as RF Turbines, looks and feels bulletproof at about half the cost of the RFs. This place carries about everything you are looking for. webcyclery.com
    Brian
    Zippy, the wonder bike
    I got some Truvativ FireX cranks off ebay for $35.00. They are pretty light I think and seem to work nice.
    Ebo
    Ebo is offline
    I'm running XT 180mm M737 5 bolt, square taper cranks with a 32t Spot ring and Spot bash guard. Just got the crankset brand new on Ebay for $90 and will use the rings when needed on one of my geared hardtails. Say what you will, but I still think the older(mid 90's) Shimano cranks were fine chit. Plus the chainrings are far more durable than the crap they use now. The 8 spd drivetrain is an upgrade from the current 9 spd setup. My 2 cents.
    Tame the Penguin!
    Reputation: El Beastro's Avatar
    Truvativ Stylo SS w/Race Face ISIS Signature double bearing FR BB
    I got them from Larry at www.mtnhighcyclery.com. He's got another set there in his shop if you are looking for something immediately. I'll personally guarantee you won't find them any less expensive anywhere on the web.
    NedwannaB
    Reputation: JMac47's Avatar
    XTR w/Spot splined ring
    Clean & light setup!
    NedwannaB
    1 more thing...
    .....last post came from another mcculloch!!
    Reputation: the Inbred's Avatar
    hot! my next crank purchase will surely be Middleburns.
  1. Trek 930--replace large ring on Sugino Impel
    By journey in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-02-2004, 05:22 AM
  2. '98 Trek 930 & replacing Sugino ring
    By journey in forum Trek
    Last Post: 04-01-2004, 09:08 PM
  3. Can FSA carbon road crank handle rocks?
    By Rocky in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-05-2004, 01:11 PM
  4. Need a new mid chain ring. Which one?
    By DudeOnABike in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-30-2004, 12:13 AM
  5. chainring sizes for 110bcd - crank trade?
    By qtip in forum Singlespeed
    Last Post: 01-28-2004, 11:20 AM
