    crank help (x-post drivetrain)
    No, I don't have a drug problem. However, due to some leg problems, I was told I might do better with some wider cranks. (Don't freak out PeT. )
    I currently run 170mm Sugino XD300 cranks with just a middle ring on my SS. The Sugino's are inexpensive, and not too heavy after removing all the steel rings. They are actually pretty darn good. I use a IRD 118mm square taper BB, (I did this because I also have a Speedhub) so its not like my q factor is all that narrow to begin with.
    Because I need to go wider, I'm kind of thinking I need to get some external BB cranks instead of the Middleburns I probably really wanted...
    So, any suggestions based on the above info? I won't spend more than Middleburns would have cost. Should I get Shimono XT's, Race Face Evolves?
    I want a good crank that doesn't weigh more than my current setup (I'd like to actually loose weight if I can)...
    Bump, because I could use the suggestions...
    XT's because they are wide, or Middleburns with a wider than 118mm BB?
    Reputation: MMcG's Avatar
    Jul 2003
    What about some Hones or LXs?
    Saints?
    Quote Originally Posted by MMcG
    Saints?
    I doubt they are any wider than XT's though.
