Results 1 to 18 of 18
Thread: crank fail
    crank fail
    hey all i broke my crank never seen it happen before and to be honest if some oen told me about it id have a hard time believing it. so here is a picture.
    was on a night ride bout a third of the way in when we hit a steep up hill. i missed the line so i turned around and re did the hill. my second or third pedal stroke i heard a pop. the bike was still moving so i figured it was something dumb. when i go to the top of the hill and looked at my bike, i realized the tight spot on my chain line had shifted. upon closer look i found that. It was an XT crank.
    so here the plan let see you crank, frame or single speed related failure.
    stumpjumper 29 evo
    Jabberwocky
    Gt peace 9'r
    SE Lager
    meatier showers
    Dec 1999
    Looks like you ziptied it good as new.
    --sParty
    disciplesofdirt.org
    Mtbr Forum Sponsor - Homebrewed Components
    if shimano doesnt warranty that, i'd be pretty pissed as it's an obvious flaw
    yeah i bought it used so im sure they wont cover it.
    stumpjumper 29 evo
    Jabberwocky
    Gt peace 9'r
    SE Lager
    Jan 2009
    i am starting to distrust my four-bolt crank.
    Reputation: idaz's Avatar
    Nov 2007
    chainring position?
    Are those cranks designed to have the chainring running in the outboard position? Not sure it would or should make a difference, just curious.
    Cheers,
    M
    Quote Originally Posted by idaz
    Cheers,
    M
    honestly not sure they are designed to have three rings on them :P
    stumpjumper 29 evo
    Jabberwocky
    Gt peace 9'r
    SE Lager
    Quote Originally Posted by mack_turtle
    you just gave Sparty a boner.
    meatier showers
    Dec 1999
    Quote Originally Posted by ISuckAtRiding
    That ain't sayin' much...
    Anyway the truth about cranks designed to employ 3 chainrings is this. The two non-granny rings are supposed to share the job of structurally supporting one another & the bolt circle. Take one ring away and bolt hole failure can happen more easily. Personally I'm not a fan of guard / bash rings, but at least these do the job that the 2nd ring was intended to do.
    {boing}
    --sParty
    P.S. 5 is better than 4. Sorry.
    disciplesofdirt.org
    That ain't sayin' much... not hard to do.
    {boing}
    --sParty
    At your age?! I'm impressed!
    meatier showers
    Dec 1999
    Notice I edited the "not hard" part... those words strike fear into a guy my age... I'll be 57 on election day... I said *election* day... anyway, funny how age sneaks up on ya... I wasn't always this old.
    I keep tellin' myself it's the lucky ones who make it this far.
    Right?
    And I keep riding my bike like I'm in denial.
    Which I totally am.
    Okay, let's go back to talking about crank failure. Or is that what we were talking about all along?
    --sParty
    disciplesofdirt.org
    bi-winning
    Reputation: rkj__'s Avatar
    I've seen that happen to a couple of carbon cranks.
    Reputation: crazy8's Avatar
    I've seen this happen when a bolt/ bolts where not tight enough.
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    cant go wrong with a 5 bolt square taper set for you next purchase
    "If women don't find handsome , they should at least find you handy."-Red Green
    Can't go wrong with 4 bolts either as long as they're torqued to proper spec. I'ts also a good to use steel bolts rather than alloy on SS.
    Reputation: kcaz's Avatar
    The only failure I see here is the public school system.
    That's right, I said it. Condemn.
    ballbuster
    Reputation: pimpbot's Avatar
    I'm going with....
    Quote Originally Posted by nickcarll
    loose chainring bolts caused that. 4 arm, its especially important that they are all torqued down. One works loose, it puts a ton of strain on the remaining three. Personally, I use blue loctite on them to keep them from backing out.
    I've seen two rings be destroyed by loose rings but never a crank.
    stumpjumper 29 evo
    Jabberwocky
    Gt peace 9'r
    SE Lager
