Results 1 to 7 of 7
    "the" fashion advisor
    Reputation: Chic's Avatar
    Sep 2004
    Crank arm options to run a spiderless front ring?
    I'm looking to put together a singlespeed crankset and like the idea of doing a spiderless ring (Spot or maybe even Boone Ti) setup. The plan is a 32 tooth (based on rear cog I have at the moment).
    I've seen folks do this with the older XTR stuff (M952 I believe), it also appears I could simply buy a White Industries Eno crankset although not so sure on the square taper bottom bracket although the crankset itself is good looking--saw those at WebCyclery for like $185.
    Can I pull the arms off an older XT crankset as well and set it up like the XTR with a splined spiderless ring etc? If so, is it the octalink stuff?
    I've also seen some posts here about using a Truvativ stylo crank that way although the posts I've seen don't seem to spell out which model Truvativ folks are using--any help there?
    Other suggestions? Thanks!!!
    Flight Junkie
    Reputation: IBIKEAZ's Avatar
    Here's one of your options
    I have the M952 crank arms with octalink BB(supergo $220.00), and Boone Ti ($105.00). I think it looks and works great. This is a 32 tooth Boone. Scott
    Good job!
    I LOVE that look, not bad too for $3.30 per tooth
    I have the ENO Crankset with a Stainless Phil Wood BB and at a Buck-Eight-Five can't detect any flex, just pure joy! .....er, Pain ..... Whatever.
    I'm thinkin' my next chainring will be a Boone although there is absolutely nothing wrong with the White Ind. rings IMO.
    Enjoy whatever you buy it's ALL good stuff!!!!!!
    Reputation: fritZman's Avatar
    Boone told me that they've just recently mapped the FSA spline.
    I'm planning on getting one of their spiderless rings for my FSA carbon cranks.
    Quote Originally Posted by fritZman
    Hhhmmmmmm - That'll be pretty sporty too! ! ! ! !
    Quote Originally Posted by IBIKEAZ
    That is the most awesome crank/ring setup I have ever seen. I think I'm now motivated to convert my XTR cranks.....
    spiderless
    the truvativ cranks that can be run spiderless are the stylo singlespeed ones. they are nice, and i think cheaper than the others mentioned (xtr and white ind.). But dont be put off by the white ind. being sq. taper...a mate runs them with a ti bb and still reckons they are some of the stiffest things he's run!
    ps. does anyone know if boone are the only ppl doing truvativ spiderless rings???
    any other suggestions???
    You'll have to speak up, I'm wearing a towel!!!
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. 54 42 30 Xc Crankset ? ! ?
    By reisenhaure in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-05-2004, 05:50 PM
  3. <NEED> JUST a left crank arm
    By NoDunut4U in forum 29er Bikes
    Last Post: 09-29-2004, 08:11 PM
  4. front deraileur and compact double crank
    By rapid tourist in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-20-2004, 01:34 PM
  5. chain binds up on smallest crank ring
    By ewarnerusa in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-10-2004, 09:23 PM
