Results 1 to 3 of 3
    Jun 2005
    Correct chain tension
    Just converted my vert dropout mtb frame to ss. Chainline is dead-on and I also purchased a Rennen tensioner. Bolted everything up and wondering if there is a rule of thumb on how tight chain should be? Is it better to be on tight side or loose side?? Thanks.
    Quote Originally Posted by wingnutz
    Start with 1/8" - 1/4" of sag on the top run of the chain and experiment from there. Is your tensioner spring loaded or soild? If spring go ahead and wind it up tight. Ride some rough stuff and see the the chain comes off. I always lost mine on a rough downhill when it was to lose. I don't think that you need to worry about the chain skipping it will bounce off before it skips. Make it tight enough to keep it from jumping off. Excessive tension will cause premature component wear.
    "I've never been better .... nor cared less!"
    Jun 2005
    Thanks for the advice"chop"
    Yeah, I don't need any excessive component wear as I just bought the ENO and installed a Phil Wood BB $$$$.
  1. popped a chain link -- time to replace chain??
    By journey in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-29-2005, 03:27 PM
  2. Should I shorten my chain?
    By Vulcan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-08-2005, 09:20 PM
  3. What do you use to lock up your bike?
    By LavaPunk in forum General Discussion
    Last Post: 02-06-2005, 01:20 AM
  4. Good info on bike locks.
    By 2melow in forum General Discussion
    Last Post: 02-06-2005, 01:02 AM
  5. Noisy chain when in middle ring- HELP!!!!!!!
    By HPilot in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-01-2005, 10:49 AM
