Results 1 to 38 of 38
    Retro Grouch
    Reputation: aka brad's Avatar
    A Cool Way to Tension Horizontal Dropouts
    Okay, I'm sure I'm not the first person to figure this out, but I also don't think it's common knowledge either. This came to me almost by accident. I have been riding my new to me SASS with fixed/freewheel. I occasionally flip the hub to the use the freewheel and have to re-tension the chain. For those that have not had the honor, it is almost impossible to get a chain exactly the right tenson with axle nuts and track forks, ie horizonal dropouts. The mere action of tightening the nuts usually effects the tension. This is so cool because it's easy and it works first time, everytime.
    First, pull the wheel back to tighten the chain, keeping the wheel centered and tighten the non-chain side axle nut. The chain does not need to be overtight, just tighter than you want. Now reach over and with one hand, put a wrench on the chain side axle nut and with the other hand, pinch the chain about 1/8" (or more depending how loose you want the chain). Kepp the chain pinched and tighten the chain side axle nut. Vuala, your chain is tensioned exactly to your specs!!
    Just one more rep and I get the toaster!
    Out there
    Looks loose to me. This is what chain tugs are for.
    All problems in mountain biking can be solved by going faster, except the ones that are caused by going too fast.
    Reputation: canascrews's Avatar
    Thanks for that bit of information . I will give it a try tonight . I can never get it right the first time .
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    Quote Originally Posted by pinkheadedbug
    agreed
    "If women don't find handsome , they should at least find you handy."-Red Green
    organically fed
    Reputation: w00t!'s Avatar
    That's not tensioning a chain. That's just installing a wheel. If my bike had horizontal dropouts, I'd have no problem tensioning my chain because I've been installing wheels on horizontal dropouts since I was like 9.
    My problem is finding the best/cheapest/easiest way to tension a chain with vertical dropouts.
    Tensioning a chain with horizontals dropouts is not even a question, you just install the wheel properly.
    Retro Grouch
    If you can tell an improperly tensioned chain from my photo, you should get a job with the Kencha. Otherwise, I think chain tugs are clunky and unnecessary; especially when I know I'm going to have to R&R the hub/wheel and retension it several times during a ride.
    If you keep in mind the rotation of the nut, doing the NDS first doesn't really effect the tension. The DS wants to pull the wheel forward and the NDS back.
    Axle tensioners are the fastest way to do tension the chain after wheel removal unless you're using different sized cogs. Touching the chain is also very messy at times.
    Retro Grouch
    Quote Originally Posted by w00t!
    Is that a Zen thing, like "you're not making bread, you're mixing dough"?
    organically fed
    Quote Originally Posted by aka brad
    Not really.
    Given how much debate exists in the SS culture about the best way to tension a chain, your "method" is not really a method at all because horizontal dropouts negate any debate on how to tension a chain. The debate exists for, and is applicable to, the rest of us.
    More than a few people probably clicked on this thread hoping to discover a cool way to tension their chains, but then all they saw was the way they used to install their wheels on their BMX bikes when they were in 6th grade.
    I thought it was a tension device as unique as the spoon one
    Retro Grouch
    Not really.
    Okay, i get it. Maybe you should spend a little more time in this Forum, instead of showing up now and then to rattle a cage and then going back to NorCal, The fact is you on your BMX probably did not ride sustained downhills at 20-30 mph. One reason for chain tugs, is a slightly tight chain will tear up a hub and slightly loose chain come off. Most SS riders with tugs tighten their chains in increments .5 mm at a time. Chain tension is so important that their methods of improving chainring roundness on a crank and some chainring/crank manufacturers certify the combined roundness. BMX on the other hand is notorious for out of round chainrings, so I can understand why you would think that any one could eyeball the chain tension since give or take 1/4 inch will do the trick. I'm sorry you found my heading confusing so I'll change it for you and other NorCal Forum types, who seem to think the singlespeed forum should only be about tensioning chains on bikes with vertical droputs.
    Reputation: Velobike's Avatar
    It's not a bad idea IMO. Probably solving a problem most of us raised on track ends don't have.
    I would have the chain tighter than the picture though.
    What I would suggest is a slightly modified sequence:
    1. fasten the lhs with the chain over tight
    2. pull the rhs forward slightly and then fasten the rhs nut
    3. loosen the lhs nut slightly and then retighten it.
    That should remove any stress on the axle from pulling the rhs forward while the lhs is fastened.
    I don't squeeze my chain, but I'll try it. I usually carry a rubber glove in my tools for dirty jobs anyway.
    Hope that makes sense. I use that tightening sequence and don't get any movement.
    Latitude: 5736' Highlands, Scotland
    well most people already know how to tighten there horizontal dropouts but this is a somewhat good method if you cant afford chain tugs
    Retro Grouch
    Quote Originally Posted by Velobike
    You just described how I used to tighten a chain. First I'm really anal about chain cleanliness, so it's not a dirty job for me; also you really don't need anymore than slight finger pressure. I know this sounds like I'm making a big deal over nothing, but once you try it you'll see what a mean. Squeezing the chain allows you to tension the chain to a such degree of accuracy, that it's one of those things that make you go hmm.
    Retro Grouch
    Quote Originally Posted by nuck_chorris
    Or don't like/want them.
    WWYD?
    Reputation: johnnyb's Avatar
    What's with the NorCal types anyway?
    You are absolutely right that a tight chain will tear up your hub.
    But do you know about centering chainrings? If you want smoothness in your drivetrain you have center the chainring in its bolts. I have to say chaintensioners are good to have for safety. Falling on your bike or off of it from a thrown chain is not fun. It probably will happen on or after a climb when the torque pulls the wheel forward in the slot. I feel that you can't tighten a bolt enough not to move after strong efforts.
    Tensioners keep the side-to-side alignment easy.
    Now I'm going to go off on one of my favorite NorCal trails.
    Out there
    The bottom half of the chain is sagging. Unless you have some savage tighty-loosey action going on, there's some slack to take out.
    550 is offline
    newble
    I have a little bit of slack (exactly as pictured as far as I can tell) and it never causes problems.
    No good hearted deed goes unpunished. Or even uncriticized for that matter. :-/
    I have a Bianchi SOK 29er SS.
    What I want to know is if that is how clean your chain always looks , what kind of chain lube are you using ?
    550 is offline
    newble
    Brad what are your thoughts on something like this?
    http://www.ebikestop.com/sinz_mini_c...ck-91-6054.php
    Not for BMX though, it is a bianchi SOK29er
    EDIT: Ahah... those are chain tugs. Nevermind ;-)
    Chain tugs, FTW. Wheel position in the dropouts should not have to be adjusted during a ride, period... especially with a nutted axle. I use an internal cam QR with redline chain tugs and the wheel just does not move. As the chain wears, a quick minute with a 5mm allen key tensions the chain up and centers the wheel. It's damn convenient. Why not?
    Chronic 1st-timer
    Dec 2005
    Once you go slack, you never go back.
    Trailwrecker at large
    Retro Grouch
    Quote Originally Posted by sunset1123
    So I take it, the idea of having a flip/flop hub (fixed/free) should prohibited.
    Ah... I see. No, not at all.
    I have played around with dingle speed setups, flip-flop setups, etc. many times before, and wrestled with changing gears out on the trail. Nowadays, I decide which it's gonna be before the ride and leave it there, and deal with the consequences.
    If I was going to have to take the bike apart to change gears while out on the trail, I would run a bike with a derailleur and a few gears. If you don't mind the time/trouble, more power to you.
    Still, on a flip/flop setup with fix/free, the chaintugs are even better! Assuming you have the same chain length on both sides, flip the wheel, install, and press the chaintugs into place... presto, instantly centered and tensioned.
    Retro Grouch
    The bottom half of the chain is sagging. Unless you have some savage tightly-loosey action going on, there's some slack to take out.
    Unless you have a NJS or similar setup the accumulated tolerances will result in a noticeable out of round drivetrain. The JIS standard (ie Shimano) allows a maximum of .5mm out of round. The NJS standrad is .05mm. I have several NJS cranks/chainrings and the quality is jewel like; the chainring literally snaps into place. Of course that comes at a price most would not want to pay. There are ways to mitagte the problem as discussed by Sheldon Brown. BTW, you may have missed that I ride the bike with a fixed gear.
    Chain Tension
    The chain tension on a fixed gear is quite critical, and is regulated by moving the rear axle back and forth in the fork ends. If the chain is too tight, the drive train will bind, perhaps only at one angle of the pedals (chainwheels are not usually perfectly concentric). It should be tight as it can be without binding. If the chain is too loose, it can fall off, which is quite dangerous on a fixed gear.
    Set the rear axle so that the chain pulls taut at the tightest part of the cranks' rotation. One at a time, loosen up each of the stack bolts, and tighten it back just finger tight. Spin the crank slowly and watch for the chain to get to its tightest point. Strike the taut chain lightly with a convenient tool to make the chain ring move a bit on its spider. Then rotate the crank some more, finding the new tightest spot, and repeat as necessary.
    This takes a little bit of your hands learning how hard to hit the chain, and how loose to set the stack bolts, but it is really quite easy to learn.
    Tighten up the stack bolts a bit and re-check. Tighten the stack bolts in a regular pattern, like the lug nuts on a car wheel. My standard pattern is to start by tightening the bolt opposite the crank, then move clockwise 2 bolts (144 degrees), tighten that one, clockwise 2 more, and so on. Never tighten two neighboring bolts in a row. You may prefer to go counterclockwise, but try to get in the habit of always starting at the same place and always going the same way. This reduces the chances of accidentally missing a bolt.
    Once you have the chainrings centered and secured, adjust the position of the rear axle to make the chain as nearly tight as possible without binding. Notice how freely the drive train turns when the chain is too loose. That is how freely it should turn when you are done, but with as little chain droop as possible.
    IOW, if you are consistently tightening your chain to zero sag, then you are torturing your drivetrain like a Gitmo interrogator
    Retro Grouch
    Unfortunately that is not the case; however that also assumes your fixed cog and freewheel are the same diameter with the same tooth profile. As you know it doesn't take much to change chain tension. Now, don't get me wrong, I think chaintugs do their job very well, I just don't think they're necessary if you know what your doing, so I was throwing out a technique that makes the job easier.
    you dont want to take up ALL the slack, make it too tight and the chain will stretch
    Ovaries on the Outside
    Reputation: umarth's Avatar
    +1- I use redline's chaintugs on two of my bikes. It does take a moment longer on the flip flop, but once you set it, you have perfect tension that you won't have to mess with for a really long time, so I think they are indispensable with track dropouts. On other drop outs, like the Surly Cross-Check, Brad's method is the way to go.
    Retro Grouch
    Quote Originally Posted by canascrews
    I use "Rock N Roll Gold"; it keeps your chain and works well. The only caveat is you have to brush the dust off your chain after every ride or two and re-apply.
    Plastic homer
    Reputation: Moval49er's Avatar
    Worked fine on my first bike with track ends - thanks.
    Out there
    Didn't say take out all the slack, but there is a good 1/2" there, which is about twice as much as I ever have.
    WWYD?
    Unless you a NJS or similar setup the accumulated tolerances will result in a noticeable out of round drivetrain. The JIS standard (ie Shimano) is a max of .5mm out of round. The NJS standrad is .005mm. I have several NJS cranks/chainrings and the quality is jewel like; the chainring literally snaps into place. Of course that comes at a price most would not want to pay. There are ways to mitagte the problem as discussed by Sheldon Brown. BTW, you may have missed that I ride the bike with a fixed gear.
    Chain Tension
    Sheldon Brown is a god! This is where I learned to center the chainring.
    achiever
    Reputation: redwarrior's Avatar
    I have a question related to centering the chainring (I think). I tensioned my chain tonight and found that there is quite a tight (or loose depending on how you look at it) spot. I was thinking it was the chainring but it goes through more than one complete crank revolution before it tightens up again.
    This would indicate that the chain has a tight spot, correct? Or am I missing something?
    WWYD?
    Quote Originally Posted by redwarrior
    If it tightens up while turning the crank, its probably the chainring alignment. If the chain links stay in the same position (i.e. bent) as it comes off the gear or ring, that would mean a stiff link.
    Retro Grouch
    You also may want to check your rear cog and see if it is bent.
    never ender
    Reputation: fat_weasel's Avatar
    Jan 2005
    Bet you it's the ring...if it's off-center it might feel like the tight spot doesn't match with the crank revolutions. Take the ring off and see whether the marks from the spider are all lined up.
    If I'm right, you gotta drive out and meet me for a ride tomorrow.
    awesome
    Reputation: dblspeed's Avatar
    Quote Originally Posted by Schmucker
    quite the opposite, when you tighten the nut the DS pulls back (chain tension increases) NDS moves forward
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    Cool looking bike. You should go all silver surfer on it and get a silver post too (and bars and stem).
    I don't use chain tugs on any bike with axle nuts either.
