Results 1 to 5 of 5
    May 2010
    Converting Shimano compatible DT240 to singlespeed?
    I have a set of wheels with DT240 hubs, Shimano splined, that I'd like to use on my SS rig, with Chris King ss cogs. Can the DT240 be converted?
    I'm going to build a second set of wheels that will be for a geared bike. Worst case scenario would be tearing my current wheels down and rebuilding with a new hub. I'd rather NOT do that. Second question--if there's not an easy way to convert the existing DT240 that I have, can I get a DT240 singlespeed hub and just swap out the hub body that the cassette or cog mounts to (between the standard dt240 and the ss dt240)?
    What day are we riding?
    Reputation: Rockin's Avatar
    Quote Originally Posted by lawfarm View Post
    All you need is the cog and a spacer set.
    Also, most SS hub bodies are shorter than geared ones.
    May 2010
    Quote Originally Posted by Rockin View Post
    Great!! It looks like the splines on the cog are different from a Shimano hub, though. Are they the same?
    Warrior's Society
    Reputation: mtnbikej's Avatar
    ALL mountain bike hubs have the same spline pattern on the freehub body.
    This changes a bit when we start talking about road hubs.
    I crashed hard enough on my Tallboy to break my leg,
    The carbon is way more durable than most people.
    new name, old member
    Reputation: Bike Whisperer's Avatar
    King SS cogs will work great on the DT240 hub, it's wide at the base so it wont dig into the aluminum freehub body. Just need some spacers.
    Single and loving it (single speed bike that is)
    http://mtnbiker72.blogspot.com/
    http://www.ccfa.org/
Hot Deals
Contests
Latest Mountain Bike Articles
