Results 1 to 20 of 20
Thread: Cogs...
    Semi-Pro Ameteur
    Reputation: PacificPilot's Avatar
    Nov 2008
    Cogs...
    Right.
    I'm building a singlespeed DJ with a Hope ProII SS rear hub. I figured this would be the place to go for recommendations on where to buy cogs for said hub. Preferably in the smaller tooth counts
    As an aside - I'm completely new to the single speed world. The hub came with spacers, but will I need a lockring too? Or can I just have some spacers with a cog and the bolt on the dropouts on the end (it's the 10x135 bolt type)?
    Cheers all!
    Let's take Colorado and go chill with the British Isles.
    Reputation: scooter916's Avatar
    you will need a lockring, your LBS may have one left from an old worn out cassette, or you might have one in your own parts box. look at Surly cogs, work great and won't chew up the AL freehub body. The Surly cogs are avail in every size from 13-22t
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
    Reputation: asphaltdude's Avatar
    Quote Originally Posted by PacificPilot
    Bigger = better
    Ride more!
    Semi-Pro Ameteur
    Nov 2008
    Quote Originally Posted by asphaltdude
    Already ordered a nice, small 25t chainring up front. At least it's 7075 T6 so hopefully it won't fall apart immediately. And you can rotate the mounting position.
    http://www.deitycomponents.com/termite_sprocket3.htm if you're wondering.
    If I ever build a non-DJ or BMX singlespeed then I'll follow the Surly peeps' advice...
    Forgot to say thanks for the link!
    Word. Boone Nothing better.
    awesome
    Reputation: dblspeed's Avatar
    Surly cassette cogs. And as mentioned, you will need a cassette lockring to keep it in place.
    Baby Bear is in the house
    Reputation: r1Gel's Avatar
    Quote Originally Posted by scooter916
    FYI, the Hope Pro II SS hub has a steel cassette body.
    Better to have and not need it, than to need it and not have it.
    Semi-Pro Ameteur
    Nov 2008
    Quote Originally Posted by r1Gel
    One of the reasons I chose it
    Mine is aluminum.
    Semi-Pro Ameteur
    Nov 2008
    Quote Originally Posted by croscoe
    Mine is aluminum.
    Really? That's weird...I was under the impression all the SS ones came with steel freehubs...
    From the Hope catalog pdf thingy...
    PRO 2 TRIALS/SINGLE SPEED
    BOLT AXLE
    SPEC:
    CNC machined in Barnoldswick, England
    Built and hand finished in UK
    Bearing type: Cartridge
    (61903, 61802, 61902)
    Hub Body: 2014 T6 aluminium
    Colours: Silver, Black, Red, Blue, Gold & Gunsmoke
    Hole Drilling: 32, 36
    Cassette body: Steel
    Ratchet type: 4 pawl (48t engagement)
    Weight: Rear 361g
    What year is yours?
    What year is yours?
    If I'm not mistaken, the Pro II SS/Trials rear hub is a new product (2008?).
    Semi-Pro Ameteur
    Nov 2008
    Very possible, I am an SS virgin so i'm not sure.
    My Pro 2 SS/Trials hub is at least 3 years old, so they been around for a while.
    The body is steal and I've only seen AL bodys for the standars Pro 2 hub, so far...
    Quote Originally Posted by Juanmoretime
    I've contacted the guy and he is not even taking orders any longer
    If you do not care about weigth just buy a cog with a wide base to save the body and check that the teeth are not to wide for you chain. Generally there are 3 sizes, from very wide 3/16, middle 1/8 and narrow 3/32 (7-9 gears)
    If you have trobble finding one there are quite a few brands in shops that carry Trials stuff e.g. www.tartybikes.co.uk
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    I've been happily using On-One's Groove Armada steel cogs but I am not sure how small you can get.
    The lockring I had left over from a Deore cassette works perfectly on my Pro 2 SS/Trials hub.
    Quote Originally Posted by twestis
    Have you tried here?
    http://www.singleandfixed.com/shop/c...ram=cid%3D2%26
    Thanks a lot!
    I've searched the web extensively for Ti cogs and totally missed that page
    Now I'm in flow :-)
    Also found these guy's www.actiontec.us/prices.htm that offer Ti SS cogs, 17-22T but at a higher price then Boone...
    Previously I found www.cycle-dynamics.com/ but they do not respond to email and the site looks kind of old.
    $85 for a cog? Shove it!
    Here's a shot of the aluminum cassette body. Notice the grooves from the '6 speed' cassette:
    As I'm sort of a WW an Alu SS/Trials body caught my interest but according to Hope they do not manufacture an Alu SS/Trials body as they would be too weak.
    Reputation: AK47's Avatar
    Check out Rennen Design Group cogs: http://www.rennendesigngroup.com/Cog_Desc.htm
    They have a thick spline interface to prevent hub damage. They are really light, affordable, and look great. PricePoint has them as well.
