Results 1 to 10 of 10
    dvn
    dvn is offline
    Reputation: dvn's Avatar
    Cog for Kona Unit
    I just ordered my first SS. A Kona Unit. It comes with a 18t cog and I was thinking I might want to start out with a 20t. What type of cog do I need? I assume it's a cassette style but want to be sure before I order one. Any suggestions?
    Get a Surly cassette cog.
    There are many options out there. Just be sure to get one with a wide base. I prefer my HBC SS cog, or a King.
    Look at:
    Niner, Endless Bikes, Chris King, Surly
    There is a thread not to far down here in the Singlespeed section title something like "Your favorite Cog"
    Dec 2005
    I'm pretty sure the stock Unit uses a singlespeed freewheel. Ride the 18t for awhile and get a White Industries ENO when you decide what you want.
    puts the FU in fun
    Reputation: CuzinMike's Avatar
    The Unit uses a Formula DC52 per their website, which I have on one of my bikes. It is cassette-style. I like Surlys as they're wide enough not to damage the splines, but there are tons of other choices.
    Everything in moderation. Including moderation.
    Reputation: Bike Whisperer's Avatar
    It uses a steel freehub body so even a cheap cog like a Dimension will work fine
    Dimension 20t Splined Cog BMX or Singlespeed : Amazon.com : Sports & Outdoors
    Jan 2005
    You will need the park hcw 17 for the lock ring, but the retail on the stock cog is like $4 so even if you just bought a couple sizes to play around with your not losing much money deciding what size cog you like before buying a fancy one. The stock 32-18 is a solid gear for rolling terrain. I have a q2 pro cog on my unit with a 34-19 set up.
    I just used my open ended bottom bracket tool for the lock ring. The tips fit just right to get it off and on without eating it up.
    Reputation: blackgriffen_1's Avatar
    May 2010
    Use absolutely any cog to start out with. Once you're comfortably set on your gear ratio, swap to any of the aforementioned wide-base cogs. You won't find a decent cog that doesn't have a wide base, so don't get bogged down by all the choices.
    Surly is my go-to choice, after using the same 16t for my first three years of single speeding, then just wire-brushing the crud off of it; good as new!
    As mentioned above, this is the thread you want:
    your favorite rear cog?
    dvn
    dvn is offline
    Thanks for all the responses guys. I'll ride it for a bit with the 18 and go from there.
  1. Spam: Kona Unit, Kona Honzo, Salsa Selma Ti
    By appleSSeed in forum 29er Bikes
    Last Post: 05-10-2012, 01:09 PM
  2. New Kona Unit
    By Sac29 in forum Singlespeed
    Last Post: 10-18-2011, 07:06 PM
  3. Kona Big Unit
    By bikenut316 in forum 29er Bikes
    Last Post: 05-28-2011, 02:18 PM
  4. Kona Unit ? ? ?
    By charliethetuna in forum 29er Bikes
    Last Post: 04-10-2011, 04:07 PM
  5. 09 Kona Big Unit
    By FROZENSS in forum 29er Bikes
    Last Post: 03-17-2011, 05:03 AM
