Results 1 to 15 of 15
    climbing with high gear ratio
    Just wondering if anyone on here ride steep technical (rocks and roots and narrow) climbs with high gear ratios?? lets say higher than 2:1 ratio
    my bike (26er) is currently on 34:15 and it's been pretty easy for commuting however when i hit the trails last saturday, I couldn't climb MOST of the hills, there are a few steep and rocky hills and i had to push most of them.
    I'm thinking of lowering the gear ratio but I would really like to know if anyone out there could clean these types of climbs on 34-15 or higher??? reason I'm asking is that I'm a bit reluctant to lower it JUST after my first failure and also cause i commute with my bike most of the time. Thought if someone else could do this (which means it is a mission possible), then I should just man up and keep riding til I can do it instead of taking the easy route.
    So is 34:15 just not meant to do these type of climbs (i notice a lot of people ride less than 2:1) or is it just a matter of rider's ability??
    Thanks everyone in advance =)
    Reputation: ravencrow's Avatar
    good god man, 34x15? Jeez, my knees hurt thinking about pushing that. I ride 32x16 (2:1) and I STILL have a bit of trouble going up very steep quick inclines. That extra one or two teeth makes a huge difference.
    Ne quid nimis.
    Nothing in excess.
    one chain loop
    Reputation: fishcreek's Avatar
    32:15 is doable on hills and still fast enough on flats. tire choice is important too, the ones with the lowest rolling resistance.
    everything sucks but my vacuum cleaner.
    Out spokin'
    Dec 1999
    Commute and ride off-road with the same bike? You, my friend, sound like a perfect candidate for a dinglespeed.
    Feel the love.
    --sParty
    disciplesofdirt.org
    May 2005
    High Gears!
    Feel the love.
    --sParty
    Yea, that or do the 4 tooth rule.
    I also have a 26" full rigid 34/14 gear.
    Very fast! Biggest pain is the cramping on climbs after an hour or so.
    Never had cramping at all with the 32/15 gear.
    Did a race amonth ago with a 32/14 gear and cramped on the climbs after an hour and a half.
    32-34/15 is about the limit for a fast uncramping on the climb gear for 26" IMO.
    a.k.a Slacker
    I commend all you guys that can turn that type of gearing. I'm on my third ride, doing a 32/20 and I'm still dying.
    I'm with OhSchitt on this one, except I use 32x16 pretty well. Will say that I have walked a couple of huge hills lately though
    Ne quid nimis.
    Nothing in excess.
    Reputation: Andy R's Avatar
    Nov 2008
    Quote Originally Posted by OhSchitt
    But as you know - there's hills and then there's hills
    What I mean is, it's pointless asking other people what gearing they use and being over-influenced by their answer when they're not you, they don't ride where you ride or do the same type of riding. There are plenty of hills around here that I could happily climb on 32:16 (I'm talking 26er here BTW) but an awful lot that I can't, either because they're very long and very steep, or steep and a very soft draggy surface or whatever.
    My most used ratio is 32:19 - it lets me deal with the climbs the best (too low a gear for some though) and I can still spin out at 15mph on the flats. In winter I usually go as low as 32:21 as most of my riding is in forestry and it's muddy and draggy with plenty of steep pitches and tight switchbacks.
    I'd rather have a gear that will let me ride 99% of the stuff and put up with it being spinny on the level, than the other way round.
    I know that I run lower gearing than a lot of people, but it works for me and, if you can spin well, you can still get around at a fair rate of knots.
    seems like I'm really running too high and asking for trouble =), guess I may just have to go 34-17 or 18.
    AndyR -
    =) yes I understand it's more of a personal preference and depends on the trail types.. but I just want to see if anyone out there could do those loose steep climbs with high gears so i know im not trying to achieve something that is not possible..(if you know what i mean =P).. sure I can always go lower a gear whenever i can't climb something but then i would have lost my point to riding a singlespeed =D (that's just me)
    Thanks guys for the reply =)
    808+909 = Party Good Time
    Reputation: chumbox's Avatar
    Feel the love.
    --sParty
    Or a fixie flip flop rear hub
    SSolo, on your left!
    Feel the love.
    --sParty
    yup..............
    Quote Originally Posted by Andy R
    Useful information can be obtained, but unless you've ridden with the particular person on the trail(s) that are being discussed, it is very hard to get a good direct comparison. But still useful info, just have to call it a guide. And yeah I wouldn't go to high....bettter to spin a lil bit than kill yourself on the climbs....or ya could walk the really tough ones and gear a lil higher.
    Get off the couch and ride!
    Reputation: mtbyker's Avatar
    Mar 2006
    If you run a high gear long enough you will get stronger, but just as importantly you will learn how to balance at the really slow cadence times.
    a.k.a Slacker
    Quote Originally Posted by Natedogz
    yup..............
    Walk the trails, that's blasphemy! just kidding. I do try to avoid having to do a hike a bike, especially if I'm riding solo - if i'm in a group and don't want to slow them down, I will. I'll stop and rest try to gather my strength a little and try the hill again though.
    I think you should start from a ratio that match to your optimum performance on a geared bike (if you have one, that is) or the pace of your buddies’, then work toward upping it. Else I would totally burn out, or get disappointed badly. Therefore, I wouldn’t use gear ratios as your absolute scale (at least) initially.
    What I mean is this - I started SS last fall, and at that time I was much slower and got totally wiped on my SS, compared to my geared bike. But I was able to ride most of the foothills steeps somehow, although there was a little walking involved. So I decided to stay on SS. Recently, I started to cut my time by 5~8% on my SS on good days, compared to my geared bike. And I don't have to walk although I still stop a couple of times to catch my breath. But it's getting much better. If I can cut my time by more than 10% later in the year, no walking, and less (or no) stopping, then I’ll take it that I’m getting better and a time to up the ratio. In my opinion, repeatable measureable improvements are better than all-out tryout and burn out. It's a challenge I brought to myself, and I actually enjoy seeing some (slow) improvements. My wife laughs at my time-trial board in my garage. Just my 2 cents.
    You could probably do it if you were a pro level cyclist. I've seen the Lalondes run 36:16 (29er) on a course that I barely clear everything with 32:18. So it's doable, but you have to not only be strong, but be able to carry your momentum.
