    Reputation: a4racer's Avatar
    The Christmas Conversion...
    I'm going use my holidays over Christmas to convert my HT MTB to a SS!
    I've been reading this forum religiously for about a month, and I've finally set up a plan...but I'd love to be able to get your feedback on what I need that I haven't noted, or what other gear choices make more sense...my goal is a fairly lightweight SS that will primarily be used on flattish singletrack (Ontario doesn't have much in the way of hills!)
    I'm currently riding a 2003 Rocky Mountain Vertex which is stock, except for Avid Ultimate brakes and levers, and Chris King hubs laced to Mavic 717s...
    First upgrade (can you call it an upgrade?): Spicer Ti fork (435mm, suspension corrected) swap for SID XC.
    Rear wheel: I'd like to run the Phil Wood Eccentric Hub, laced to Mavic 717...this means I don't need a chain tensioner, right?
    Crankset is a little tricky--I'd like to be able to swap SS to Gearie fairly simply, but I don't know what sort of SS crankset is compatible with the LX crank and BB, which I believe, are integrated...
    Suggestions?
    Sep 2004
    I suggest you search ebay for some good old fashion square tapers. Preferably something common so you could get two drive sides...
    Cranks and BBs...
    ...interesting thought! I could do this...
    Square taper BB, and then get one Race Face Turbine crank (or other), get a drive side Turbine crank, so I have swappable cranks for SS and for Gearie...Not a bad idea!
    It seems fairly simple though to convert a drive side crank from Gearie to SS and back..just take off the big and granny rings, install a bashguard, is that about it?
    Sep 2004
    Yeah but to be honest I'd just have two different arms. I also dont think half the people that have bashguards need them. For me it would just be unnecessary weight.
  1. Deus XC Crank for Christmas
    By paddlefoot64 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-18-2004, 04:29 PM
  2. Replies: 21
    Last Post: 12-17-2004, 11:55 AM
  3. Soulcraft conversion kit skinny
    By TwistedCrank in forum Singlespeed
    Last Post: 10-26-2004, 11:12 AM
  4. Cassette hub to fixie conversion?
    By Mattman in forum Singlespeed
    Last Post: 04-02-2004, 08:02 PM
