Results 1 to 5 of 5
    Cheapest Eccentric bottom bracket?
    Picked up a cheap 29er frame that needs a EBB, 54mm ID and 68 width. this will be for a beater/around town single speed. the cheapest EBB i've found is the carver for about 100 shipped, is there anything cheaper than that? not worried about creaking and won't be pushing this bike even remotely hard.
    Reputation: davesauvageau's Avatar
    What frame is it? Just making sure you need the expander type and not the set-screw type EBB. I had a Gary Fisher Rig and the EBB drove me nuts. I couldn't stand it so I switched to a Karate Monkey frame.
    My motorcycle runs on infant blood
    I thought the expander types were interchangeable?
    mine looks like this
    so i take it this is for the set screw type EBB then. is phil wood EBB my only option?
    thanks
    PMK
    PMK is offline
    Reputation: PMK's Avatar
    Quote Originally Posted by zedaristo View Post
    Yes that will work, or should work based on the sizes you mentioned. Your other alternative may be to hit a road bike forum such as that on Bikefroums.net, and ask in the tandem section since some have swapped out that same style or the Cannondale styles for the lighter and better quality Bushnells.
    PK
    Reps! We don't need no stickin' reps!
