    Enthusiast
    Reputation: JonathanGennick's Avatar
    chainring bolt question
    Quick question -- I hope -- about chainring bolts:
    1) I'm running a Shimano LX M582 crank on a singlespeed setup. Currently I have a middle chain ring and bashguard.
    2) However, I am thinking to replace the bashguard with an MRP Mini-G. I just realized that I'll need shorter bolts.
    So bottom line: I want to run middle-ring only on the crank set. What size chainring bolts should I buy?
    Enthusiast
    Follow up: Will BMX bolts like the following work in my application?
    http://www.danscomp.com/459000.php?cat=PARTS#
    Quote Originally Posted by JonathanGennick
    That's what I use.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Just got curious: is there more than one diameter standard for those bolts?
