Results 1 to 5 of 5
    try driving your car less
    Reputation: jh_on_the_cape's Avatar
    New question here. chainline on either side of ENO eccentric?
    Is the chainline the same on both sides of an ENO eccentric? I ask because I was thinking about making setting up the fixed side with a tall gear, but same chain and a bigger ring in the front, in the big ring (outboard) spot. I want the rear V brake to still line up.
    Would this work? I realize that the outboard front chainring will make a different chainline. On the freewheel side it lines up with the middle ring nicely. 32:18 or 34:18 sometimes. I want to run maybe a 36:14 fixed or so for dirt roads and mellow stuff.
    Thanks.
    Only boring people get bored.
    Quote Originally Posted by jh_on_the_cape
    Thanks.
    umm... I'll just take that as a no.
    Medium?
    Reputation: Fast Eddy's Avatar
    On my roadie
    I run the chain ring on the outer position, and there are ENOugh threads that I could space the cog out even a little more. I think it would work fine. Try it.
    Quote Originally Posted by Fast Eddy
    Thanks... I think I might just try it...
    Reputation: ernesto_from_Wisconsin's Avatar
    works fine
    Thanks.
    it works fine. For a few weeks I had a track cog on the fixie side while pedaling with the ENO freewheel. When I decided to go back on to fixed, chainline never changed. But do change your underwear though.
  1. ENO eccentric build
    By Travis Bickle in forum Singlespeed
    Last Post: 10-23-2004, 08:10 AM
  2. ENO eccentric build
    By Travis Bickle in forum Where are the Best Deals?
    Last Post: 10-22-2004, 11:05 PM
  3. F'ing chain keeps falling off!!!!!!!
    By liaudio in forum Singlespeed
    Last Post: 06-24-2004, 07:26 AM
  4. ENO eccentric and bike trailer?
    By Higbee in forum Singlespeed
    Last Post: 05-21-2004, 11:24 AM
  5. ENO eccentric hub questions
    By AlexB in forum Singlespeed
    Last Post: 03-12-2004, 03:41 AM
