Results 1 to 5 of 5
    Faster Than Your TV!
    Reputation: iconoclaSSt's Avatar
    Chain tug on a Cross Check?...
    Anybody using a chain tug on their Cross Check. If yes, do you need to?
    Just thinking about a sudden axle slip on my fixie while bustin' up a steep one and thinking that it would be a very bad thing.
    Cracker-magnon
    Reputation: gpsser's Avatar
    Quote Originally Posted by iconoclaSSt
    It has the semi-horizontals, right? If so you could do <b><a href="http://forums13.consumerreview.com/crforum?14@13.abNpapOp6no.0@.efe6196/1">something like this</a></b> that was posted recently on the old board. Takes a little bit of modification though.
    "Life is a F@#^ing story problem, get used to it - my son.
    I am the owl
    Reputation: riderx's Avatar
    Use some proper track nuts, crank them down nice and tight and you'll be fine. Been doing it for quite a while on the crosscheck and the frame before it.
    SingleSpeedOutlaw .com
    Riding Bikes and Drinking Beer.
    Smile XCheck SS
    I've been riding a SS XCheck for 2 years now without a tug, with QR cassette wheels. Tighten it down hard and you should be OK. I commute up a fairly steep hill for 10 miles and it has never slipped. Good Luck, AlaskaPat
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    I'm now running my SS CC with a Surly hub with nuts, that should be tight enough to last a lifetime. Before I use a Shimano QR on a standard hub. I might invest more time in filing and grinding the dropouts rougher, but I manage a 2-hour fun ride or a 1-hour race on it before the chain slackens up unacceptably.
    The Surly wheel came from my Pacer (non-SS specific frame), I think I'll have it stay on the Cross-Check now, SS specific hub on a semi-horizontal fram,e it makes sence. It was always a pain to get the Surly nuts past the Surly Singleatorwhen chaenging the wheel. I guess I'll try to true an old road wheel and put that in the Pacer with a crit gear of 52-16. The Cross-Check (latest buy) will do duty as a commuter. Now 34-16 for CX racing, cummuting probably 42-16 or thereabouts. My commute is long and flat with only some bridges (DUH, I'm from Holland).
  1. Buy some PRIME mt.bking land (check this out davis)
    By crashedandburned in forum Passion
    Last Post: 01-14-2004, 03:30 PM
  2. Replies: 13
    Last Post: 01-13-2004, 02:14 PM
