Results 1 to 10 of 10
    Reputation: Flat Ark's Avatar
    Chain Tensioner - Up or Down?
    I am building up a SS using an 09 Salsa Mamasita. I know that there are "magic gears" but I don't want to limit my gearing purely for the sake of aesthetics. I have a Surly Singleator and I'm not sure if I should run it with the spring tension pushing up or down. Does it even matter? Looking at the chain slack I think that I could use it either way. Would like some opinions from those with experience. Thanks.
    Pushing up is best because you engage more teeth with the chain.
    Rigid Surly 1x1 650b-------- CrossCheck--------Surly Pacer-------Salsa Ala Carte
    a.k.a Slacker
    Quote Originally Posted by Frs1661
    Agreed.
    Pushing up for all the reasons stated so far.
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    +1 on pushing up
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Ok, I'll push up. Thanks!
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    up.
    but not because of better chain wrap. unless one is running a 14t or smaller cog they will not have any increased efficiency, power, decreased wear, or (insert reason here) by the "increase" in chain wrap or tooth engagement. and even then it would be minuscule at best.
    however, up generally seems to provide a tighter chain with less slop and bounce which is desirable for a number of reasons.
    it looks better too.
    however, if one changes gearing a lot by more than a couple of teeth then they should consider a push down spring because it will allow them to have a longer chain to accommodate the gearing variations than will a push up spring.
    "Knowledge is good." ~ Emil Faber
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    sorry to ruin the up streak, but i prefer down. 1. its easier to take the wheel off. 2. the frame i have is weird so i cant push up
    "If women don't find handsome , they should at least find you handy."-Red Green
    Well, I guess it is going to have to push down anyways. I thought that I could use it either way but the stays on the Mamasita are a little too wide. Can't wait for my wheels to come in.
    Reputation: EBasil's Avatar
    I prefer "up" and use that on my primary bike. It does mean I've got to manipulate things to get the wheel on and off, but that's not the biggest issue -- the Singulator springs are too weak to hold things firmly so, like many" this means I used a helper spring created out of free-range rubber bands, ho ho.
    On my wife's SS, I used a Performance stores singulator knock-off that only pushed down but secures very well. There is less teeth engagement but it works very well and she doesn't have a rubber band looped around her chainstay.
    Do what works and get the chainline straight.
