Results 1 to 3 of 3
    Jan 2009
    chain tension options
    sorry, another of these threads.
    i have a a Gunnar Rockhound frame (415mm chainstays) with vertical dropouts and and a Paul Word hub. it's geared at 32/18, which is a bit spinny even for a noob like me. i also have a new 1/8" bmx chain (KMC 710 "kool") because i don't trust those flimsy race chains. i can never get the tension just right. currently, i took the shouldered centering washers off the hub bolts and i am running the axle slightly below the center of the dropout.
    i am considering two options:
    1. add a half-link to the chain (i have one in my toolbox) and put a chain tensioner on it. i can get a tensioner from my LBS for $20.
    2. get a 17t freewheel, which would bring my gearing up a bit and should fit just about right according to my calculations on this site: http://eehouse.org/fixin/javafmu.php
    the problem with (2) is that, once the chain starts to stretch, it will be loose and i will have to buy a new chain again or get a tensioner anyways. but i want that higher ratio at some point, might as well start now.
    Magic gearers do tend to have to change their chains more often, cause that's their only option. You've answered your question, get a tensioner. But I thought the Rockhound had
    sliders? You're saying it's a vertical dropout?
    Jan 2009
    nope, it has vertical drops.
    i am going to get a 17t freewheel for now and when the chain starts to stretch, i will have saved up some money for a decent tensioner. right now i don't have enough spare cash for one, but i can afford a $15 freewheel. the $20 tensioner they were going to order for me at the shop looked cheesy, so i'm not settling for that. that will bring my gear ratio a little higher, which is something i wanted to do anyways. thx.
