Schmucker said:
Those two things are nothing alike. A bungee cord stretches because the elastomers have been reoriented within the material to have that elongation, but they maintain their chemical binding. The material has actually deformed. A chain, however, "stretches" from moving the links further apart from the space available. You're just moving parts around. There is no deformation. What you're saying is that having to blocks next to each other, and then moving them apart, you've now stretched the blocks.
Nope, that's not what I'm saying. A chain is one, single unit. It's made up of many components. None of those components stretch under normal use. Those components wear down under normal use. This results in the chain, as a single unit, becoming longer. This is the definition of the word 'stretch', becoming longer. 'Stretch' does not apply strictly to elasticity.
"stretch (strch)
v. stretched, stretch·ing, stretch·es
v.tr.
1.
To lengthen, widen, or distend: stretched the sweater out of shape.
2. To cause to extend from one place to another or across a given space: stretched the banner between two poles.
3. To make taut; tighten: stretched the tarpaulin until it ripped.
4. To reach or put forth; extend: stretched out his hand.
5.
a. To extend (oneself or one's limbs, for example) to full length: stretched her calves before running.
b. To extend (oneself) when lying down: she stretched herself out on the couch.
c. To put to torture on the rack.
6. To wrench or strain (a muscle, for example).
7.
a. To extend or enlarge beyond the usual or proper limits: stretch the meaning of a word.
b. To subject to undue strain: to stretch one's patience.
8.
a. To expand in order to fulfill a larger function: stretch a budget; stretch a paycheck.
b. To increase the quantity of by admixture or dilution: stretch a meal by thinning the stew.
9. To prolong: stretch out an argument.
10. Informal To fell by a blow: stretched his opponent in the first round.
v.intr.
1. To become lengthened, widened, or distended.
2. To extend or reach over a distance or area or in a given direction: "On both sides of us stretched the wet plain" (Ernest Hemingway).
3. To lie down at full length: stretched out on the bed.
4. To extend one's muscles or limbs, as after prolonged sitting or on awakening.
5. To extend over a given period of time: "This story stretches over a whole generation" (William Golding).
n.
1. The act of stretching or the state of being stretched.
2. The extent or scope to which something can be stretched; elasticity.
3. A continuous or unbroken length, area, or expanse: an empty stretch of highway.
4. A straight section of a racecourse or track, especially the section leading to the finish line.
5.
a. A continuous period of time.
b. Slang A term of imprisonment: served a two-year stretch.
c. Informal The last stage of an event, period, or process.
6. Baseball A movement in which a pitcher, standing with the glove side facing home plate, raises both hands to the height of the head and then lowers them to the chest or waist for a short pause before pitching the ball. It is used as an alternative to a wind-up, especially when runners are on base.
adj.
1. Made of an elastic material that stretches easily: stretch pants.
2. Of, relating to, or being a vehicle, such as a limousine or passenger jet, having an extended seating area that provides extra space for more passengers, leg room, or amenities."
