Results 1 to 24 of 24
Thread: Chain slip
    Jan 2011
    Chain slip
    I'm new to SS and I'm really struggling with a repeatedly slipping chain.
    When I am climbing steeper hills it comes off with a bang!
    My bike is a voodoo wanga set up with surly hubs and a shimano free wheel.
    I have tried changing the chain tension many time but it changes nothing.
    Would it be worth getting it professionally service/aligned or even try a new chain, free wheel (eno?) or crank?
    I love the bike. Loving single speed. But I just want it all to work.
    Any ideas?
    openwound
    Reputation: voodoochild's Avatar
    Check your chain line.
    -- let's ride
    Jan 2011
    I believe I have been but please elaborate in case I'm missing something obvious.
    Jan 2011
    openwound
    Take a look at the FAQ, up in the upper right corner of the page. There's a discussion of this and a link to info on how to check it. Good stuff.
    -- let's ride
    Reputation: masterofnone's Avatar
    My guesses would be a loose chain, a chain with a nearly broken or a stiff link, chainline (viewed from the back wheel the cogs front and back should be as close inline as possible), worn chain and/or cogs, bent or missing teeth, or a failing freewheel. Best results are using SS specific cogs and chainrings with no shifting ramps or "half teeth" (I don't know the correct terminology) to aid shifting, although I have used them with success if the chainline is perfect. Singlespeeding puts a lot of stress on the drivetrain, minor flaws will rear their ugly heads sooner than geared bikes. If you're riding a converted bike with a chain tensioner like a surly singulator the spring tension may be too low.
    up n over
    Some chains don't like ss free wheels...
    "my cat's breath smells like catfood."
    -ralph wiggum
    Dive Bomber
    Reputation: jackspade's Avatar
    Your chain size should match the cog size.
    The chain that fills the cog should perfectly fit, less gap is better.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    maybe it's the hub?
    Honestly... ahh I give up
    beware the grammar police
    Reputation: paco664's Avatar
    its elves.... definitely elves....
    or your chain line isn't correct like everyone else said....
    either one... both...
    owner and founder of www.moto-rush.com motorcycling community
    Nov 2008
    I agree with matching your chain to your chainrings/cog. I had this same issue when I built up my One9. I put on a bmx style singlespeed chain thinking they it was stronger than the skinny 9 speed chains. Kept dropping the chain when I would attack the hills. My chaninline was good, so I switched to a 9 speed chain and haven't dropped the chain in the two years since the change. Also, I have since learned that the 9 speed chains are as strong as the bmx style chains. Hope this helps.
    Blackspire Mono Veloce chainring with Surly cog.
    May 2005
    I had real chain-drop issues with my SS Rockhopper (sliders), but no issues with my SS Stumpjumper. The main problem on the RH was keeping chain tension.
    Make sure all the parts (chain cog and chainring) have the same amount of wear. an old chain with a new chainring or vise versa has been know to cause issues.
    up n over
    Maybe somebody put a banana in there..
    -ralph wiggum
    Feb 2007
    chain
    used to have same issues, even w good chainline. switched to KMC kool chain and it helped a good bit. but start with the chainline/correct chain size.
    Make sure you have the right chain size first, I have a BMX chain and it works great (they ARE meant for SS set up), and insure correct chainline. Then make sure it is as short as possible, mine slipped when I first built it, I took one link out (made the tensioner a tight fit) and it works awesome now.
    up n over
    Eat a Bologna sandwich and wash your hair with vinegar.
    After that go to the bike shop and get some one else's eyes to look at it.
    -ralph wiggum
    Retro Grouch
    Reputation: aka brad's Avatar
    How about a photo of your setup?. It does sound like a chain mismatch, but one has to go out of their way to get an 1/8" chainring or freewheel (even Surly has gone to a thinner chainring to accommodate a 9 speed chain); so I'm guessing a bent chainring tooth and a chain that's probably too tight.
    Just one more rep and I get the toaster!
    Pwning Trails
    Reputation: phlite's Avatar
    As others have said either:
    1. mismatched chain and cog, e.g. 3/32 cog with a 1/2" x 1/8" chain
    2. chain line out of whack
    Check the chain line, I thought mine was dialed but had it looked at at the bike shop and it was way off ;( .
    Jan 2011
    After Much Tinkering That Only Made Things Worse I Went To Local Bike Shop And They Told Me:
    1.chain Line Was Slightly But Not Horribly Out.
    2. Shimano Freewheel Was Worn
    3. Chain Had A Kink
    4. Rear Wheel Skewed
    They Recommended
    1.new Freewheel (changing To 20t To Reduce Torque When Climbing)
    2. New Chain (can't Remember The Brand But It Looks Much Sturdier)
    3. Setting Up Everything Again In A Straight Line. From Scratch.
    While Not A Mountain Bike Specialist They Deal With A Lot Of Fixed Speed/single Speed Conversions Due To A Big Bicycle Polo Scene Around Here.
    I'll Find Out Tomorrow How It All Works...
    up n over
    Finally a solution.
    Hope they got it set for u.
    -ralph wiggum
    Jan 2011
    YBN MK918N half link chain.
    Acs 20t cog.
    All working great.
    I must say that 20t is great improvement on 18t I previously had. Trails that daunted me before are a breeze now.
    Quote Originally Posted by elsewhere
    A banana in the tailpipe?
    up n over
    I ain't falling for no banana in the tailpipe!
    -ralph wiggum
