Results 1 to 9 of 9
    Chain falling off
    Repeatedly. Alignment was right, tension was right.
    Surly front and rear, 8/9 speed chain. 08 XT cranks.
    I'm thinking my chain is too narrow. Thoughts?
    I actually like SRAM chains so would like to stay with these.
    Do I need a narrower chain? If so, will a PC-1 work?
    THANKS!!
    Reputation: 7daysaweek's Avatar
    I ran a KMC Z410 chain on surly stuff for 6 or 8 months and NEVER once dropped the chain. Plus they come in cool colors.
    That's probably the route I'm going.
    How's your J-Wock treating you?
    Sorry to threadjack but i have a quick newb question. How to i make sure my chain is aligned? I have an 08 XXIX with an EBB. Just adjust the BB until the chain looks straight? Or, is there a more precise way of doing this?
    You need to measure it. There is a sheldon brown article on it, in fact.
    http://www.sheldonbrown.com/chainline.html
    Reputation: Cygnus's Avatar
    no, i don't think a narrow chain will solve your problem. there is no problem with using a 1/8" chain, as long as the chain isn't defective.
    i use an 8 speed chain (SRAM) on my fixies and SS bikes. have never thrown a chain.
    something isn't adding up. chainring loose or bent? extreme frame flex? bad (stiff) link in the chain? wheel straight in the dropout?
    Quote Originally Posted by gsomtb
    Well I've had it for about 9 months now and still haven't found a single thing I don't like about it. I've fiddled with some parts, done some fine tuning but I'm loving it.
    Feb 2006
    This is on my converted Zaskar. Surly push-up singlerator with SRAM 1/8" chain never dropped on me, even through rocky drops
    This config wraps more of the chain on the rear cog. Bulletproof so far.
    Wider
    Quote Originally Posted by Cygnus
    I think I need a WIDER chain b/c (I think) the Surly stuff is slightly wider than other brands. (I said narrower in my OP but it was a mistake!!)
    Everything is lined up properly and the frame is stiff (J-Wock)
