Results 1 to 29 of 29
    Mar 2013
    CF fork for SS...
    I have the SS Salsa EM and am very happy with it. Did upgrade the brakes to XT and swapped to Renthal chainring and Surly cogs. Now considering a CF fork as an upgrade. I have searched and found comments mostly on the Niner fork but not so much on the Whiskey or others...
    Can folks share their experiences with the various CF forks on a SS please?
    My opinion--unless you're building up a race rig, don't spend that much $$ on a CF fork. It does lighten up the front end and some forks have tiny bit better dampening than the stock EM fork, but bang for buck is very low. Get a better wheelset instead.
    If you want more cush up front, get Knards. I just got Knarded up front and the thing's on hit.
    Apr 2013
    I've been using a Niner CF for 18 months and could be happier. Not flexy, very well made and its very point and shoot. The others I investigated leading up purchasing didn't seem as good. Just MHO, YMMV.
    Reputation: AlexCuse's Avatar
    The niner forks are pretty money, but you'd definitely get more bang for your buck with a nice tubeless wheelset. I do think the dampening of the carbon forks is a *lot* better but I've only compared it to the last 2 generations of karate monkey fork.
    At the end of the day I decided to go with a custom steel fork (for $100 less than the niner ) but I did pick up one of these for a song that has been pretty nice On-One Carbon Fork
    Yeah I only carry cans cause I'm a weight weenie.
    Apr 2013
    I've been running tubeless so long I forget what it was like to run tubes. That being said, while the Niner forks are just a bit more that other CF forks, they are well worth the cost. I'm all about you get what you pay for. I'm so happy with my Niner fork someone will have to go a long ways to get me to switch.
    Jun 2010
    I recently mounted a 2.35 Hans Dampf to my steel fork and it rocks. Running 20psi with no issues. Love this tire and really smooths out the trail. Having ridden both and steel fork I prefer steel. Just a personal preference.
    Aug 2010
    CF fork for SS...
    Have had both niner steel and carbon.
    Much prefer the carbon fork. Well worth the money.
    Mar 2013
    Appreciate the comments....sorry I posted before work and did not get back till now...forgot to mention currently running the stock wheels tubeless with Racing Ralph 2.4 BUT I my LBS is building Chris King/Stan Flow wheels for me as I type.
    I appreciate all the Niner feedback anyone run the Whiskey? I expect I will upgrade the EM before too long although I love it every day.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    CF fork for SS...
    Another one been real happy with my niner carbon fork.
    Definitely running rigid up front is where it's at if you're standing and climbing.
    SPP
    Rigid.
    Ride,Smile, Pedal Damn it
    Reputation: henrymiller1's Avatar
    I'm in same boat. Don't know what i want. I have an On One CF fork on my 29er. It is so flexy. I feel it and can see it. I don't like it at ALL. Hoping to pick up a Niner CF.
    CF fork for SS...
    Happy with my Whisky. Nicer looking too. Available in Thru axle with 44 offset. I have a 9mm version and regularly switch between TA squish fork. Chris King hubs makes this easy with simple axle swap.
    Biking At Home Dad - blog Being a dad and racing singlespeeds
    HIS & HERS Energy Efficiency What pays for the next bike(s)
    White and nerdy
    May 2012
    There is a reason all other forks are compared to the niner. Get the niner fork.
    Quote Originally Posted by henrymiller1 View Post
    Are you running the "race model" (or whatever on-one call their monocoque fork). I ask because I find the niner fork slightly flexier than the segmented on-one fork I linked above. The cool thing about the niner fork is that even under heavy breaking, it flexes to a certain point and then *really* stiffens up. The on-one fork does this as well but it tends to waver around that point a tiny bit - this may be because I run a 185 front rotor and my brother runs a 160 with his niner (both with bb7's), but I suspect it is because of the way the carbon is laid up on the niner fork. It really is an engineering marvel.
    If you're looking to save weight the niner fork will definitely do that, but if you are looking for something that is a whole lot stiffer you might be better off looking elsewhere. I've only ridden the ones with the 1 1/8" steerer - imagine the niner fork with the tapered steerer / thru-axle (the RDO I think) does make for a significantly stiffer ride, so if you have a tapered headtube that would probably be worth a shot if you've got some money burning a hole in your pocket.
    For reference I'm about 225 lbs geared up.
    Jan 2011
    I run a chisel on my ss stumpy, absolutely love it paired with a 2.3 ground control. much more comfortable compared to steel I've ridden. Although I got it as a new bike take-off so the $$ was no where near as salty.
    is it better to have QR up front than Thru axle for moe flex if running rigid? I just love TA on fs bike but can see on rigid SS QR may be better?
    Get the Niner. Rode both the 1 1/8" version and the tapered for multiple seasons. Forks are wicked.
    MCH Co-Captain
    Reputation: stremf's Avatar
    Dec 2012
    The Niner forks are nice, but unless I become a spandex flaunting weight weenie, I'm sticking with steel. If I ever wanted more compliance from a fork, Walt would get a call from me.
    May 2012
    I was talking to one of the niner guys about my new rdo fork. They said that it was designed to have similar flex front to back as the QR version just stiffer laterally.
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
    Feb 2010
    Niner here, picked mine up for $200 when Jensen was blowing them out. Where else can you spend $200 and save 2lbs over the stock Redline steel fork? And 3lbs over my Reba? That's what, $6.25/oz? That's pretty far from weight weenie territory if you ask me.
    Thanks for info. I want something light. The On One i have vibrates under heavy braking, 160mm 175lbs rider. Its not the Mono version. Are you suggesting the Niner may do the same thing? I have a vassago steel coming ( while i wait). thanks
    I've been running a bontrager switchblade carbon fork. Love it. No vibrating and extremely light. I weight 210lbs and I ride hard. No issues at all.
    I picked mine up on ebay for $125
    nothing to see here
    Reputation: Stevob's Avatar
    CF fork for SS...
    The niner doesn't vibrate at all
    I see hills.
    I want to climb them.
    Reputation: bkirby10's Avatar
    Feb 2012
    Personally, I have seen CF failures over the years and I just don't want to subject myself to thew danger. So I swore long ago nothing on my bikes will ever be CF! To each their own though...
    As for now, I can't say enough about a steel Niner or Salsa fork with a Knard 1/2 fat frontend. It couldn't be better for me but again, to each their own...
    Mar 2013
    What rim are you running the Knard on? Tubless?
    Feb 2012
    Right now, Knard is on a P35 rim with a tube and no trouble. Will go tubeless for that wheel soon. Absolutely love it!
    Oct 2012
    I run the DT Swiss XRR470, it's for some flex but I feel it works in my favor. Just enough to take the edge off. So far it's been a awesome addition to my On One Inbred. I run a conti race king 2.2 at 23lbs and I'm at 160lbs.
    The niner seems to get pinned back quickly and stay there, even with just a 160mm rotor.
    I've only used the on-one with 185mm rotors. I do get some chatter when braking hard on pavement, but I haven't been able to replicate it on the trail. Wonder if the 160s don't have enough leverage to bend the fork back to the point where it "settles down". I'm not a materials engineer so I won't take that thought any farther.
    Either way I doubt you'll be disappointed with the niner. Its a tremendous fork, and the custom one that is in the mail is gonna have to be real good for me to not regret picking one up
    Reputation: Flat Ark's Avatar
    CF fork for SS...
    Quote Originally Posted by bkirby10 View Post
    I've seen an aluminum steerer snap off of a WB carbon fork. I've seen a scandium Niner One 9's top & down tube snap completely in half while the carbon fork stayed completely intact. I've seen both aluminum and carbon bars snap. I've seen both aluminum and carbon posts snap. I don't know where I am going with this.(?) lol
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Quote Originally Posted by Flat Ark View Post
    Nice. I'm running a Niner steel fork on my SIR and would probably go carbon but I'm saving up for a suspension fork for another ride. I run two sets of carbon bars, two carbon posts and one carbon wheel set now too eheheh. Honestly, I don't notice a huge difference between aluminum and carbon bars; carbon post on my SS is a bit more forgiving and carbon wheel set (with db 1.7 weak/1.8 strong side spokes) is definitely stiffer than Flow's with 2.0 straight spokes.
    One of the most technical riders where I live rides a Niner carbon fork that goes over obstacles others (50 lbs. lighter than him plus with some serious racing podium axxion under their belt) won't. I have no worries about durability. I can't see myself getting a carbon frame at present as a few lbs. lighter (~5% weight reduction) for my #195 middle-age jolly old self is not going to make a huge difference except for the nice crater in my wallet...
  1. OPINIONS: Aluminum rigid fork or suspension fork for 9yr old's bike?
    By dragbike in forum Families and Riding with Kids
    Last Post: 05-09-2013, 05:06 AM
  2. Replies: 21
    Last Post: 01-13-2013, 09:06 PM
  3. Replies: 0
    Last Post: 07-24-2012, 07:22 AM
  4. Replies: 5
    Last Post: 09-12-2011, 04:13 PM
  5. Salsa Cromoto 26" fork to replace 100mm travel fork
    By rth009 in forum Shocks and Suspension
    Last Post: 01-03-2011, 09:51 PM
