Results 1 to 3 of 3
    Feb 2013
    Cannondale Trail SL 3 SS - EBB adjustment
    Has anyone toyed around with the EBB on their 2013 SL 3 SS? I loosened it up and gave it some mallet action but it didn't want to budge so I brought it to my LBS, but they set the chain way too tight. It's a hassle for me to bring it back so I'd like to do it myself if possible.
    It has a main bolt for the compression wedges and then another tiny bolt but I have no idea what its role is.
    Any pointers?
    Jun 2013
    The tiny bolt butts against the frame, to ensure the bottom bracket assembly is aligned correctly. Make sure you are tapping the right side, you tap the wedge on the non-drive side, then allen key in the hole, to adjust, then tighten using the main wedge bolt.
    Feb 2013
    Thanks for clearing that up, I'll give it a shot.
  1. Trail SL 3 SS - EBB adjustment
    By eightyseven in forum Cannondale
    Last Post: 06-27-2013, 02:30 PM
  2. 2011 cannondale trail sl3 vs 2012 cannondale trail 5
    By idon'tlikepink in forum Beginner's Corner
    Last Post: 08-22-2012, 07:56 AM
  3. Cannondale HeadShok Si adjustment?
    By Lak in forum General Discussion
    Last Post: 07-14-2012, 08:07 AM
  4. Trek 3700, Cannondale Trail 6, or Jamis Trail X2?
    By rjc003 in forum Beginner's Corner
    Last Post: 07-09-2012, 05:44 AM
  5. Fork/Shock Trail Adjustment Cheat Sheet & Records
    By charvey9 in forum Downhill - Freeride
    Last Post: 03-08-2011, 08:04 PM
