Results 1 to 12 of 12
    Busted my rear spot axle...
    I snapped my axle and am now without a SS rear wheel.
    My frame is an old Brodie Unabomber, horizontal dropouts, so no qr hubs. My understanding is that the qr isn't strong enough to hold the wheel.
    If Spot can't fix my hub, any suggestions on a new wheel? CHEAP????
    The frame is a 135mm spacing, so that's the good news.
    Thanks for the advice.
    Pete
    Steamroller
    Reputation: Mattman's Avatar
    It should be fixable
    Quote Originally Posted by pedalpete
    Pete
    Axles are easily replaceable and most any shop should have one in stock. Also a QR skewer is usable if you run an appropriate chain tug like a Surly Tuggnutt. The chain tug will prevent the wheel from slipping forward under load. I like to use one with bolt on axles too. The nice thing about the Surly is that it come with a special washer intended for use with a QR axle. You probably would only need one for the drive side.
    Two Wheeled and Too Big
    Reputation: itsdoable's Avatar
    Same bike, same problem, happened to 2 of us. Call Spot, they'll send you a new axle.
    The problem with mine was that Brodie included chain tugs (similar to the one pictured) and that didnot allow the bolt to go in far enough, so the axle broke at the thin part right where the bolt ended. They said the solution was not to use the chain tugs - both have been trouble free since (3 years). Or you can use a longer bolt with the chain tugs (if you must). As a last resort, they can also supply a stainless steel axle for those that are extra abusive on bikes.
    Cheers,
    Tom
    Inrideo est vita
    Reputation: SSteel's Avatar
    Some of the Spot axles are not quite long enough to give decent structural strength when using a QR. I think it's a bit sketchy with tugs.
    Anyway I snapped my axle using a QR (after 1 month riding) & Spot sent me a replacement. I rebuilt it and sold it to a freind, he destroyed the bearings within another month.
    I don't think too much of Spot hubs.
    Canadian distribution: X-Fusion Shox, Rand Momentum lube and Canadian Shield fenders.
    TheRide.ca
    Facebook
    I just heard back from Spot...
    They're gonna replace the axle for me with a steel one, and only $10.
    I'm not sure why the local shop guys thought it would be so difficult, but after 8 years of use, a $10 repair sounds pretty good to me.
    NedwannaB
    Reputation: JMac47's Avatar
    Don't say that!...
    Quote Originally Posted by SSteel
    ..I just got back from lbs with my new wheel!! SPOT came highly recomended (behind Phil & Chris' ofcourse....) At least the customer service sounds great....
    New rr disc setup to go on my B.C.C. (broken collar bone club) rehab project.
    Question for Mattman
    don't mean to jack the thread, but I have an OT question for Mattman.
    what kind of chain is that? all half-lengths? seems like it may wear the cogs and chainrings less because of the better chain wrap.
    just curious,
    rich
    Reputation: iattackthedarkness's Avatar
    Quote Originally Posted by Mattman
    sorry for the hi-jack but, Mattman (or anyone else who knows), is that shadow chain compatible with 9sp cassette cogs and chainrings?
    Steamroller
    Shadow Conspiracy Interlock chain
    Quote Originally Posted by comsense
    just curious,
    rich
    It's available from Dan's Comp for about $29. It has great cool factor, it's very adjustable, and it's very strong. It is also a pain to shorten, it's on the expensive side and weighs a full pound uncut (I removed just one link). If you get one, believe what the instructions say and don't try to shorten it without the recommended tool, you may ruin your day, not to mention your tool or the chain.
    http://www.danscomp.com/ Innovative half link design helps prevent damage to side plates. Nearly twice as strong as a conventional chain. 1/8" (16.0 oz) Park CT-7 chain breaker recommended.
    Reputation: fanzy38's Avatar
    Hi Mattman,
    What kind of chain are you using on this bike ? Seems perfect when you need a half-link....
    Looking for cheap Chris king or Syncros 1", threaded headset, Mary or Mungo bars, ENO eccentric Hub...
    Steamroller
    Look up, it's a shadow interlock
    Quote Originally Posted by fanzy38
    Hi Mattman,
    The details are a few messages up in the thread.
    Whatever! Just crash it!
    Reputation: Objectionable Material's Avatar
    Sep 2004
    The good thing is that the axle will be stronger too. They've switched from aluminum axles to stainless steel because they've had so many breakage problems. My axle arrived in 5 days and after a 20 minute install process, it was ready to roll. I haven't looked back.
    Peter
    If a man talks dirty to a woman, it's sexual harassment. If a woman talks dirty to a man, it's $3.95 per minute.
    Bike Wrench Blog ** Unfortunate Series of Events
  1. Matching front and rear travel
    By Call_me_Clyde in forum Shocks and Suspension
    Last Post: 02-24-2005, 11:00 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. Need New SS Opinions
    By DirtSS in forum Singlespeed
    Last Post: 10-09-2004, 06:19 PM
  4. Replies: 39
    Last Post: 08-14-2004, 06:09 PM
  5. Drilling out solid axle off-center?
    By jh_on_the_cape in forum Singlespeed
    Last Post: 01-14-2004, 12:26 PM
