Results 1 to 16 of 16
Thread: broken betls
    blet drive
    Reputation: JUNGLEKID5's Avatar
    Cool-blue Rhythm broken betls
    has any one broken a belt on there spot long board belt drive and is there an issue with it sliping??? any help.. a local shop seems to thing that it is a big deala and wont even give it a chance..
    Save a tree & wipe your butt with an owl.
    Thank your local Sierra Club.
    The belt is toothed so it cannot slip. (much like the harley belts).
    I dunno about chances of it breaking. But they are reported to be stronger than chains and less susceptible to wear and tear.
    I'm sure if anyone had broken a belt it'd be all over internet forums like this one Tell your LBS to drag their sorry selves into the 21st century and MTFU.
    blet drive
    thats whay iv been sasying that belts are hear to stay and like it or not they work... and we need to get some in our local shops... period.
    Reputation: MellowCat's Avatar
    This is from the 29er board....
    Broken belt on brand new spot
    "When the end of the world comes, I want to be in Cincinnati because it's always 20 years behind the times." Twain
    Reputation: AM Octopus's Avatar
    I haven't heard of any of the belts breaking but...we have had a few bikes in that slip. I've heard there has been issues with bikes not being delivered just yet because of the slipping belts.
    Early on Spot was delivering bikes with chains on them and telling people that when the belts were ready that they would send them the belt, chainring and cog to change them over.
    We have a couple Trek bikes in the shop that have the belts on them and one of them we can get the belt to slip. Well I should say that some of us with enough torque can get them to slip.
    Quote Originally Posted by AM Octopus
    If you can get it to slip, you most likely do not have a proper belt line or tension.
    Quote Originally Posted by mothgils
    It's interesting that you say that because we have had one of the Spot guys in the shop (who used to work at our shop) helping with one of the bikes. Even with the belt tight enough that when you spin the cranks backwards they hardly turn we have been able to make the belt slip. Since Spot is in our town we run into people all the time on the trail that have had issues with the bikes.
    It's not as "easy" "fool proof" 'maintenance free" as Spot intended it to be when they came out with it. I think the splines need to be deeper on the belt and the chainring/cogs to get better grip. It still needs some fine tuning before the jury is out.
    Occasionally engagedů
    Reputation: Ptor's Avatar
    Even with the belt tight enough that when you spin the cranks backwards they hardly turn...
    The only belt bikes I've seen in real life were in a shop in Ft. Collins and the belts were so tight the cranks had very noticeable resistance when spinning it backwards -- that can't be good for the bearings or for pedaling/rolling efficiency. Rode one of the Spots around in the parking lot (admittedly not much of a test) and still think it's an "emperor's new clothes" sort of thing...
    "The plural of anecdote is not data." -- Attributed to various people in a variety of forms, but always worth remembering...
    Reputation: Charlie Cheswick's Avatar
    I broke a belt! I bought my Spot in November and about a month in on a short, steep climb; I broke that sucker and almost planted my nards on the stem. Anyway, I have learned a lot since then and I changed out the tensioners that came with the bike. The belt will never slip. In addition, if it is tensioned properly it will never break. The worst thing about the Spot design is that it uses the wheel quick release as the only tensioner to hold the belt. That means you really have to crank that sucker down. I think other frame makers are making much better designs to tension the belt. I saw Ventana is using a rocker type assembly that looks like it would work much better than Spot's.
    Anyway, the belt drive is awesome and I would recommend it to anyone. I will be glad to help you dudes if you have any questions about it because I think it is just the nuts for single speeders.
    Quote Originally Posted by PeT
    And with all that resistance you get a lot of noise from the belt creaking. That alone would drive me nuts. It's like riding a bike with a squeaky chain.
    My belt drive runs as quiet as an indian wearing moccasins sneaking up on John Wayne.
    Quote Originally Posted by Charlie Cheswick
    I had a similar situation with the slipping. It wasn't that the belt slipped under force but I could get the entire wheel to shift under braking and that would throw the belt line off. The Spot Rocket tensioners suck and I swapped them out with a better set. I even filed the paint off of the inside of the new tensioners so that it would grip. I combined that with a DT Swiss RWS on the rear and haven't had any problems since.
    Exactly. I feel like a ninja on the trails.
    skillz to pay billz
    Reputation: nOOby's Avatar
    yep, same here.
    Reputation: Velobike's Avatar
    I don't run a lot of tension on the beltdrive conversions I have done.
    What causes "slip" in my opinion is a flexing chainstay. This means the belt arrives at the rear cog at a slight angle and rides up on the cog.
    My bikes with laterally stiff chainstays do not need a lot of tension. I have fixed the bike with flexy chainstay by running a preventer pulley. This means again I do not need much tension even though the bike is extremely flexy. Anyone who was at SSUK09 would have seen me walking up easy hills because of this flexing (that's my story anyway ), but now it can be ridden hard without slipping.
    The pulley sits not quite touching the belt unless the belt rides up on the rear cog.
    My measure of "not much tension" is what I'd call "slightly tight" on my SS chain drive bike. (As you can see I use scientific methods )
    Latitude: 57║36' Highlands, Scotland
