Results 1 to 8 of 8
    Brake question for my conversion project
    I am converting my old Specialized frame into an SS and during the sanding/painting stage I came across an issue I wanted to get some feedback on. The frame was originally setup for canti brakes. Well the old brakes are indeed old and need to be replaced. I have a set of Vs that I was going to install and realized that the cable stops are not set up for Vs. So I began to ponder my options. I know that they sell bolt on cable stops so I could install one and go that way. I have also been toying with the idea of running full housing. Are there any other options?
    Dirt Donkey
    Do you have pics ? Canti brakes only need a final cable stop attached solidly to the frame where the cable will get its pull from. When switching to Vs all you have to do is bypass that because the stop is directly on one of the arms.
    So unless you have a funky setup you can just install the cable and housing(s) like before, only the rear will be a tad longer and won't use the last cable stop.
    Cheers,
    Maurice
    No pics yet but.....
    I thought about that except the only cable stop for the rear brake is just behind the stem. The cable is(was) then exposed all the way back to the seatpost area where is entered a cable router that is welded to the frame and centered the cable up for the the cantis. There is not cable stop back by the seatpost area. I know this sounds confusing and I will try to get some pics up.
    Oh I see. I'd go full housing and simply zip-tie the cable to the frame then.
    Maurice
    Medium?
    Reputation: Fast Eddy's Avatar
    Here's what you need
    though I don't know where to get one. Maybe Problem Solvers? This is also an old Spec. frame:
    <img src="http://gallery.consumerreview.com/webcrossing/images/clamps28.jpg">
    Edit: You might be able to attach this thingee to your seatpost QR and make it work:
    <a href="http://harriscyclery.net/site/page.cfm?PageID=49&SKU=BR7151"><img src="http://harriscyclery.net/site/images/library/catalogs/soc/p350X350/BR7151.jpg"></a>
    Also, you could send a PM to <a href="http://forums.mtbr.com/member.php?u=234799">DeeEight</a>. He may have one hanging around.
    Reputation: Cephalopod's Avatar
    Sep 2004
    I'd check out the Sheldon Brown website or give them a call and ask about the bolt-on stop Fast Eddy posted a picture of. If its something odd then they can usually get it.
    One gear to rule them all
    Reputation: 32seventeen's Avatar
    Todd............. If you can't be kind, at least have the decency to be vague
    Reputation: FrontRanger's Avatar
    Quote Originally Posted by 32seventeen
    3217 is right. I have been running this same thing for the last 6yrs with no problems. I used part of a tube as a shim since it was a little too big but other than that zero complaints.
  1. Big big big brake problem....
    By AdamOn6thStreet in forum Brake Time
    Last Post: 10-15-2004, 01:33 PM
  2. Which brake lever for which brake...?
    By mahgnillig in forum Brake Time
    Last Post: 10-06-2004, 02:18 PM
  3. Super noob general brake question
    By cb1021 in forum Brake Time
    Last Post: 09-21-2004, 03:59 PM
  4. AVID mech disc brake question, on a SS....
    By hu-man in forum Singlespeed
    Last Post: 03-07-2004, 10:48 PM
  5. Magura Marta brake drag question
    By dgangi in forum Brake Time
    Last Post: 03-01-2004, 09:42 AM
