Results 1 to 7 of 7
    Kiss my Grits!
    Reputation: Chim Chim's Avatar
    bottom bracket on Rigs
    Is it just me or are the BBs on the GF Rig pieces of sh&t?
    On the second one, in a year. Trying to adjust for a loose chain and the adjustment screw/bolt is stripping. Must be made of tin. Is there a trick that anyone knows of?
    Sometimes, with a very strenuous effort, I will fatigue.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Replace the bolt with a stronger one ? Is the bolt stripping or is the eccentric ?
    openwound
    Reputation: voodoochild's Avatar
    I replaced the stock unit with a Carver. It was a nice change.
    Expert Crasher
    Quote Originally Posted by voodoochild
    Semi-agreed...no slip, no stick, no strip, but still creaky several miles after tightening.
    If you never crash you are not trying hard enough.
    Never Satisfied...
    Jan 2009
    Where are you stripping it??? Threads or head of the bolt???
    I tighten mine down very well (I'm pretty ham-fisted) and have zero issues with it....
    Mine is great. I have adjusted it many times when changing sprockets. It has never made a sound. Make sure it is well lubricated. If you are stripping the bolt or threaded hole you must be over torqued.
    Teen Wolf
    Reputation: cr45h's Avatar
    same here!!
