Results 1 to 9 of 9
Thread: Boone Ti Cogs
    ali'i hua
    Reputation: SlowSSer's Avatar
    Boone Ti Cogs
    ok- for those of you who have them:
    how many spacers did you get?
    what hub are you running them on?
    I was told by Brett @ boone that for a standard geared casette, I'll need 25-30mm of spacers, and 5mm of spacers for a King SS hub, with the base of the boone cog being 8mm. the nice part is that the ti spacers are only 2 bucks a pop, but that can add up quickly.
    so, If I go all out and get enough chi-chi wicked bling ti spacers for the XT hub, what should I do? I know that I need a 2 and a 3 so that I can also run it on the King SS hub, but just get 4 or 5 5mm spacers as well?
    sorry- im just thinking here.
    34N 118W
    Reputation: Hollywood's Avatar
    spacers
    when I ordered the cog, I told Brett that I was using a King cassette hub (not SS). He spec'd the right amout of spacers for the cog. Are the spacers ti or aluminum? I guess I thought they were alu.
    HW
    Quote Originally Posted by SlowSSer
    ali'i hua
    Quote Originally Posted by Hollywood
    HW
    the spacers are ti, and have the splined pattern that the casette has.
    thanks for the info, jeff. i figured i'd get a replay before 50 some odd views
    Fight the Kakistocracy!
    Reputation: veelz's Avatar
    New question here. any links to the cogs? (nm)
    nada mucho
    veelz
    Gravity, not just a good idea, it's a law.
    The only one consistently and constantly applied, no exceptions.
    ali'i hua
    Quote Originally Posted by veelz
    nada mucho
    http://www.booneti.com/cr/cr.html
    JJT
    JJT is offline
    Reputation: JJT's Avatar
    I have 4 8 speed spacers on the right, and about the same on the left. Should measure the body for the exact distances.
    Currently they are on a DT 240 hub..
    ali'i hua
    beautiful pic. thanks.
    well I just put a 16T boone cog with 5 5mm spacers and needed one 3 mm ordinairy spacer on a CK rear cassette body....... nice work!
    Just talked to Brett @Boone
    Brett is going to machine a single 5mm spacer to go on my King....instead of a 2 and a 3.
    He also said we would look at chainrings for pre-03 XTR cranks.
    shiftless
    "Work Harder...Not Smarter - Single Speed"
  1. Cannondale 1FG cranket upgrade discovery
    By SoloWithOthers in forum Singlespeed
    Last Post: 01-20-2004, 06:22 PM
  2. Found cheap 17t BMX Cogs!!!
    By aka brad in forum Singlespeed
    Last Post: 01-18-2004, 04:59 PM
