Results 1 to 6 of 6
    www.justthebonnet.com
    Reputation: Capt_phun's Avatar
    New question here. Bolt on rear hubs
    I have left over 9 speed hubbed wheelsets. I was going to get spacers and an 18t cog to put on the 9 speed cassette hub. What would be the best way of attaching the wheel to the frame? I have a Biachi SISS with horizontal dropout with a spot hub right now that is a bolt on. DO I need a bolt on skewer for the 9 speed hub or would a regular quick release work? If a bolt on skewer is needed where can I find a good one at that will not slip in the vertical dropouts?
    thanks
    Captain_Phun
    Bryn Mawr Borracho
    9-speed wheel
    Good Morning,
    you could use a q.r., esp. if you'll continue to use the chain tensioners, however, I don't know if the q.r. is long enough to use in conjunction with them. If you can find an old Campy steel q.r., all the better because you can really snug those up. Otherwise, your LBS should be able to get you some bolt-on skewers, which typically use a 5mm hex wrench. If they don't have 'em, or can't find 'em, I know One-On-One Bicycle Studio has 'em (www.oneonone.com) On the flip side to all of this, you may be able to find a solid axle, or you could use a Surly Fixxer which replaces the cassette body and q.r. with a solid set up.
    cheers,
    Hurl Everstone
    Cars-R-Coffins
    carsrcoffins.com
    No relation
    Reputation: Ichabod's Avatar
    SS - for all ages?
    "ONE ON ONE specializes in customized marketing and management programs for
    retirement communities, assisted living and skilled nursing homes."
    I found http://www.oneononebike.com/, which seems more likely...
    Don't you ever, don't you ever, stop being dandy showing me you're handsome.
    Bryn Mawr Borracho
    YIKES! oneononeBIKE.com
    Sorry about that. It is indeed, oneononeBIKE.com
    carsrcoffins.com
    Just get an old Suntour or Shimano steel QR
    and it will work fine.
    It's in the SS FAQ with other fine stuff.
    http://www.mtbr.com/faq/ssfaq.shtml
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    What did you expect....
    Quote Originally Posted by Ichabod
    Hurl drinks more whiskey before 9:00 a.m. than most of us drink in a week.... and now he's hot for my sister.....
    <img src="http://gallery.consumerreview.com/webcrossing/images/wifey.jpg">
    I hope she wears a condom....
  1. Avid Mechs on Formula hubs
    By spangelsaregreat in forum Brake Time
    Last Post: 01-23-2004, 10:51 AM
  2. Another question...qr20 and bolt on 20mm interchangeable?
    By BigKahuna in forum Downhill - Freeride
    Last Post: 01-19-2004, 11:12 PM
  3. American Classic/WTB disc hubs
    By GrantB in forum Wheels and Tires
    Last Post: 01-19-2004, 08:44 AM
  4. Who all makes cassette single speed rear hubs?
    By Grimey in forum Singlespeed
    Last Post: 01-15-2004, 11:27 AM
