Results 1 to 3 of 3
    Reputation: dumpy's Avatar
    Apr 2005
    blackspier mono veloce
    Ok I have a total dumba$$ question here. I have an older bike that I think I am going to convert to a single speed. I was planning on using the crank arms from this bike (all the chainrings are shot) and this chainring. I am wondering if this chainring will fit on my circa 93 (I think) STX crank arms? They are a five bolt pattern, but I don't know much about the spacing on these, is it universal or are there different sized bolt patterns?? If anyone could help and let me know if I can use these it would be great. Thanks.
    17.5" pistons of love
    Jun 2005
    Quote Originally Posted by dumpy
    You may or may not have the ultimate turd of all cranks. I don't remember what year it was but Shimano produced stx cranks that the chainrings were totally proprietary. I think the small bolted to the middle and there was some other wierdness(odd bolt circle?). Now I remember-big bolts to middle which shares a single set of bolts with the small ring to attatch to crank arm. They look normal, but I say no dice on the 94mm ring. Take them to a shop a have them take a look, if you can get a ring buy it from them.
    The Domesticated SSer
    Apr 2005
    Quote Originally Posted by Chief Bulging Calves
    You may or may not have the ultimate turd of all cranks. I don't remember what year it was but Shimano produced stx cranks that the chainrings were totally proprietary. Now I remember-big bolts to middle which shares a single set of bolts with the small ring to attatch to crank arm. They look normal, but I say no dice on the 94mm ring. Take them to a shop a have them take a look, if you can get a ring buy it from them.
    Yup that sounds like it, the big does bolt to the middle and then all three bolt to the crank arms together. Yeah I would say that STX was the turd of all component groups (excluding all the real low end huffy stiff). I figured I could probably get away with keeping the crank arms, they seem sufficentally stiff and durable. I may just buy a new crank and do it right from the start. Thanks for the help.
  1. Just how powerful are Mono 6Ti's and Mono M4s?
    By donboyfisher in forum Brake Time
    Last Post: 03-20-2005, 10:34 PM
  2. Mono Mini or Mono M4 or other????
    By verrocchio100 in forum Brake Time
    Last Post: 03-20-2005, 04:04 AM
  3. Replies: 0
    Last Post: 10-19-2004, 12:49 PM
  4. Replies: 1
    Last Post: 06-22-2004, 09:53 AM
  5. Mono Mini 180 or M4
    By rjlpinto in forum Brake Time
    Last Post: 04-09-2004, 09:33 PM
