Results 1 to 64 of 64
    locked - time out
    Reputation: hygieneboy's Avatar
    This is the best suspension seatpost ever made in the history of the world:SR SUNTOUR
    I have herniated disks and like a cushy ride but I don't like the drawbacks of a full suspension bike. I have tried nearly every suspension seatpost made from the Tamer Pivot Plus aka Tricky Dick, to the two different Thudbusters(long & short travel) to regular designs. Either they don't do enough or they feel like a bouncy diving board. None of them felt quite right. The SR Suntour suspension seatpost transforms a hardtail instantly into a full suspension feel without any pedal bob.
    The SR Suntour parallellogram design is the smoothest and most effective design for medium to large off road bump supression and a $ $ redemption.
    It sucks that it's not readily available or marketed in the United States. I have used one that came stock on an old K2 bike for 3 years and it's finally wearing out but still functional. To order one you can sometimes get lucky on E-bay but I went straight to the SR Suntour USA distributer Doug Stuart.
    dstuart@srsuntourna.com
    http://www.srsuntour-cycling.com/SID...tail&tnid=1476
    Attached Thumbnails Attached Thumbnails This is the best suspension seatpost ever made in the history of the world:SR SUNTOUR-pict0943.jpg
    This is the best suspension seatpost ever made in the history of the world:SR SUNTOUR-pict0946.jpg
    Why didn't you like the Thudbusters? I am looking at a suspension post for my commuter. Also how much did the suntour cost you?
    Ovaries on the Outside
    Reputation: umarth's Avatar
    How much are they?
    locked - time out
    The prices range from $40 -$70 depending on which version you get (steel vs. alloy)
    Not bad. I like it.
    locked - time out
    Quote Originally Posted by ryball
    The Thudbusters are big heavy beasts, expensive and not easily adjustable or fine tunable based on weight/preference plus they boing like a diving board. This one adjusts spring tension in fine increments with a allen wrench adjustment screw at the bottom end of the seatpost. I set mine rather stiff so it only activates when I come down hard on my butt never when pedaling.
    The SR Suntour is the closest feeling to Full Suspension dampening on a hardtail.
    Out spokin'
    Dec 1999
    Is it singlespeed-specific?
    --sParty
    disciplesofdirt.org
    Mtbr Forum Sponsor - Homebrewed Components
    --sParty
    Depends on what chain you run. Definitely 29er specific.
    Quote Originally Posted by ISuckAtRiding
    My ass. Where is the anodizing?
    Quote Originally Posted by hygieneboy
    Hows it work in mub?
    I was thinking of a thud buster, thats for the tip
    Mojo
    Dosen't come in a 31.6 seat post diameter
    Mojo
    Details
    Hi, this is Doug from SR Suntour,
    The aluminum version of our suspension seatpost is now stocked for sales in the US and Canada.
    Suggested Retail Price is $79.99.
    If you are interested in one, have the local bike shop of your choice contact us at 425 354 4965. If you don't have a local shop to work with its OK to contact us directly.
    Thanks.
    Quote Originally Posted by umarth
    i think you answered your own question!
    Reputation: itsdoable's Avatar
    --sParty
    It's got no damper, so it's a single speed suspension...
    Assodizing?
    Out spokin'
    Dec 1999
    Assodizing?
    Beats assodining.
    --sParty
    disciplesofdirt.org
    I don't huck.
    Jun 2005
    holy set-back, Batman! I could never get that saddle in the right position for me...even with the saddle rails all the way forward like the pic shows. That will screw it up for a few folks. Consider that before you order one.
    Otherwise, it looks tidy and clean.
    Blog Ramblings
    West Coast writer for twentynineinches.com
    I more curious if it has a lockout or not.
    Quote Originally Posted by freshw00d
    Thanks.
    31.6 mm??????
    Quote Originally Posted by mtroy
    Haha. I could finally get my saddle back far enough to be happy.
    Cthulhu fhtagn
    Reputation: Mike Gager's Avatar
    whats the weight limit?
    Specialized HardRock 29er
    Nashbar 29er SS
    SP Singletrack rocks
    Quote Originally Posted by Mike Gager
    less if you run it on a SS.
    is buachail foighneach me
    Reputation: sean salach's Avatar
    Quote Originally Posted by Mojo Man
    31.6 mm??????
    Shim??????
    Beats assodining.
    --sParty
    depends on who's ass you're dining on.
    I mean i think I'd rather eat Megan Fox's ass than have my ass electrocuted in sulfuric acid for an hour or so, then dyed, and boiled for 20 minutes.
    Reputation: Bataivah's Avatar
    Surly a thudbuster would have a preload adjust for the amount of money they want for one.
    I don't see spending $130 or more on one with no Preload adjust. I'll have to check them out closer now. The Suntour does'nt look too shabby for $80!
    Honestly, from the few rides I have on it, I really like the Suntour.
    It seems to me (after checking out the specs on the Thudbuster), that you can only adjust for the weight of the rider. There is no tweaking adjustment at all. You have to replace the Elastomers to softer or harder according to your weight and thats the only adjustment you have. I may be on a trail and decide to stiffen it up a bit and won't be able to with that type of set-up. I also like the piston and roller design of the suntour much better just by looking at the two. I think I would have to go with the Suntour for sure! Better price really seals the deal also.
    i'm a big fan of the white bros air post. It's light,it has an oil damper. 27.2, I
    used to shim it out with delrin sleeves top and bottom on bigger frames. My back got better, these days i only use one on my powercrank bike. I have extra's, i had one rebuilt and bought the last one they had at white at a nice discount. It doesn't have the parallelagram action,but i use it for roadbiking,i'm fine with suspension on a mountainbike.
    Reputation: glader60's Avatar
    minimum seat rail height?
    Quote Originally Posted by Bataivah
    The Thubuster does have a preload adjustment see http://www.thudbuster.com/pdf/Thudbu...structions.pdf
    This Suntour looks promising. The thudbuster LT minimum seat rail height is 144mm above the seat tube. I need a seatpost for my stoker on a tandem and need the seat rails much lower than 144mm.
    What is the minimum seat rail height above the seat tube for the SR Suntour?
    ~100mm
    Reputation: Bajamike's Avatar
    Anyone know the weight or warranty on the Suntour?
    Contact us with your video production needs.
    mike@arkfilms.com
    nice and low, but can you get softer springs?
    ~100mm
    100mm is plenty low of a saddle height for my stroker, thanks.
    Now only thing is my stroker is 120 lbs and the manual shows suggested rider's weight 144 to 220 lbs (65 to 100kg).
    The manual lists softer and harder springs. I wonder how hard it would be to get/find the softer spring?
    Manual http://www.srsuntour-cycling.com/dst...X/SP8-NCX.html
    Quote Originally Posted by glader60
    Your right...I missed that 2nd page when I viewed it. I still like the design and price of the
    Suntour better though. I would like to know the weight of the two and I can't seem to find
    one for either of them. I'm going to take a wild guess and say the Thudbuster is lighter?
    Talk to Doug at Suntour. I'm sure he can hook you up, though I don't think there should be a problem with the stock spring. Backed all the way out, I can compress it just by pressing on it, and I'm sure you don't want it that soft.
    Quote Originally Posted by Bajamike
    I will try to get a weight for it this week. 2 year limited warranty.
    The way I read the OP's comments, it sounds like he says the Thudbuster weighs more.
    Frt Range, CO
    Reputation: pursuiter's Avatar
    Your right...I missed that 2nd page when I viewed it. I still like the design and price of the Suntour better though....er?
    LOL, like you have a clue what you're talking about. If you like something, great. Slagging a product you don't have any idea how it works is stupid. TB has been around for years, ride your SR for a few weeks before you proclaim it the best in the world.
    Wow, nice.
    Stateline Falls, Watauga
    Reputation: JeffL's Avatar
    Jan 2009
    Thudbuster LT 30.9mm is 586 grams.
    I loved mine. Haven't used it in a couple of years, though. Preload adjustment definitely helps with the bounce. I also found I preferred the stiffest elastomers even though I'm only 160lbs. That pretty much eliminated the bounce for me and still provided plenty of cush.
    Cane Creek service is the best. They've treated me right on several issues, and as a result I use CC components whenever possible. I wish they'd expand their line - cranks, BBs... I'd be first in line.
    Quote Originally Posted by pursuiter
    I've never used either of them. I'm trying to make a comparison of the two. And I never said it was the best in the world. I did say I like the design and price of the SR and don't have $130 for a TB. If you have things good to say about TB then post it here so we can get more than just opinions about the SR.
    One thing I do know is that both of them are better than my Kalloy that is just a couple tubes and a spring.
    SR Suntour weight?
    All That is Man
    Reputation: Zero Signal's Avatar
    Haha that thing is awesome. (In reference to the post apparently below mine now)
    I wouldn't consider it suspension travel since you really aren't seated while going downhill anyway. I couldn't imagine the hit that thing would absorb that I wouldn't be prepared for by standing.
    John
    True Suspension Seatpost
    Here is my engineering senior project that I just completed. Still in the testing/refinement stage but it is far and above better than the Cane Creek Thud Buster (which I own and have ridden). This is as close a hard tail can be to full suspension in my opinion. Fox Float R for resistance and damping. Estimated 4" of travel measured on the radius of the arm length.
    This is the best suspension seatpost ever made in the history of the world:SR SUNTOUR-seat-post-003.jpg
    True. I guess I would say ass travel or taint saving travel. I haven't taken it on any rough trails yet. Gone off a few curbs and it soaks them up easily. The rebound damping is what I was looking for.
    Reputation: GTscoob's Avatar
    That looks interesting. I know my knees would hate 4" of saddle movement, they get pissed if my saddle is 10mm lower than it should be.
    Not hating, but do you ride with hernias? 4" of saddle travel plus a beach cruiser saddle. Can you steer your bike with your hips anymore?
    Cool project nonetheless. My point on the steering is that you use a lot of balance on a bike when using extremely squishy saddles. The subtle balance of weight shifting on your hips is lost when there are multiple inches of gel padding below your hips.
    The saddle height to center of the bottom bracket distance remains relatively constant. No hernias and fortunately this prototype is on my wife's bike. I have only limited time on the prototype because my wife's bike is way too small for me.I ride a large 2010 Santa Cruz Blur LT.
    The side load rigidity is pretty receptive to steering with the hips. I agree that 4" of travel on a seat post is a little much. This simple prototype was made as a starting point and I think the travel should be reduced to around 50-75mm. The project was me just testing out my design for manufacturing, and CNC machining skills. Next project is full suspension frame.
    Feb 2013
    Suntour Suspension Seatpost
    I'm willing to try the Sountour SP8 NCX seatpost and if it does the job, replace my Thudbuster but here is the situation; My bike (Breezer Cloud 9 Pro Team Edition) uses a 31.6 seatpost but I guess there must be some sort of reducer or converter, am I right? The other thing is where do I buy it? Does it come on 400mm? or only 350mm?
    Thanks for your help...
    David Lugo
    Feb 2013
    780 grams...heavy
    Reputation: occamsrazor's Avatar
    Mar 2014
    Hi,
    Am looking to get a suspension post for my steel hardtail 29er that mostly gets ridden on singletracks. I stand for big bumps up and downhill, but the flats are also fairly bumpy and I've had some back issues in the past.
    Can't decide between the Thudbuster LT or the Suntour NCX SP-12. The LT has more travel, is a little lighter, but is bigger and requires more minimum height. The Suntour seems a more compact design though.
    Obviously there is a cost factor, but that aside - has anyone here actually ridden both, and can compare?
    Thanks...
    Just to muddy the waters even more for you... :P
    ks
    ERGON BIKE ERGONOMICS
    Reputation: AlexCuse's Avatar
    I think someone from ergon mentioned in the cyclocross forum that the post linked above is only approved for road and cross use. MTB use would void the warranty.
    Yeah I only carry cans cause I'm a weight weenie.
    Mar 2014
    I'm pretty set on either the Thudbuster or the Suntour... But thanks for the links. It would be used with a Brooks Cambium C17 saddle. The Suntour gets good reviews, but one thing I wonder is if the elastomer in the TB has better rebound.
    Between the TB ST vs LT... For singletrack use I guess the LT would be better?
    The preload adjustment is what made me decide on the Suntour.
    Rebound on the Thudbuster will at times lift you off your seat, like rolling through a dip in the trail strong rebound.
    Mar 2014
    Quote Originally Posted by ryball View Post
    Can you elaborate a bit on that? Doesn't the Thudbuster LT also have preload adjustment?
    ridin' Mary
    Reputation: OhNooo's Avatar
    I just sold my Thudbuster ST on Ebay a few weeks ago. Here's some of the text I added to the description for this product. It still sold at a reasonable price in spite of this extra bit of unnecessary honesty:
    It squeaks like crazy just like it did when it was brand new, so you don't need a bell on your bike or anything like that. Your thudbuster will tell everyone you are coming down the trail! I think the maker spelled the company wrong and it should be "Cane CREAK". The squeaking seems to get better for a ride or two when you oil the elastomer. For some reasons oiling the bushings doesn't help because the sound seems to come from the elastomer rubbing the parallelogram.
    Reputation: SRvancouver13's Avatar
    Hi All. We have the SP12 NCX seatpost up and available for sale direct from SR SUNTOUR North America.
    SP12 NCX Seatpost | SR SUNTOUR NA Inc.
    Cheers. Nick.
    SR Suntour warranty/technical advisor
    Reputation: thecanoe's Avatar
    I just put the SR Suntour seatpost on my fat bike and it is excellent. Even the guys at the ride last night commented on how plush it is. I put the TB short travel cover over it and it fits.
    Attached Thumbnails Attached Thumbnails This is the best suspension seatpost ever made in the history of the world:SR SUNTOUR-image.jpg
    Santa Cruz Tallboy
    Moonlander
    Specialized makes a nice light carbon post that has some cush called the CG-R aka Cobble Gobbler. It's made for road bikes but holds up fine off road.
    Attached Thumbnails Attached Thumbnails This is the best suspension seatpost ever made in the history of the world:SR SUNTOUR-dscn5001.jpg
    Quote Originally Posted by SRvancouver13 View Post
    Cheers. Nick.
    Nick, it seems that the SP12 NCX is very hard to find in the states.
    At this time, you are out of stock and the one ebay listing you have is at retail price with $15 S&H. The problem is not just availability, but the price is much cheaper in Europe.
    Yet the Suntour is actually smoother than both the Crane Creek offerings.
    While heavier by a large margin, the adjustability and simple adjustment is a deal breaker.
    Once again, the problem is pretty much Suntour USA who has obviously slacked on the marketing possibilities. It's not the race hounds or weight weenies who will even do a test drive, but the millions of older folks with abused bodies showing the years.
    Seriously, the SP12 NCX V1.2 is very well engineered and would be a coveted option for the butt sore.
    I found a stateside vendor for $30 cheaper than your price and the shipping at 1/3 your cost.
    http://www.empoweredcycles.com/produ...seat-post-v2.1
    For any of you who would still like to get in the saddle again, but your arse keeps telling you Duck You!
    ...Well... your wallet can complain, or your A$$
    Glad I got two, Old lady hates the TB LT so stealing her new Suntour would have been brutial. The best $220 up grade to KEEP us in the saddle and ride on.
    Jun 2016
    Seems like it's not very compatible with a Trek DS and its stock seat?
    Even thou I have the seat set all the way forward it's still too far back and my riding position gets all screwed
    Attached Thumbnails Attached Thumbnails This is the best suspension seatpost ever made in the history of the world:SR SUNTOUR-bike.jpg
    Jun 2017
    Hey guys!
    If you haven't already, you should check out our Bodyfloat suspension seatpost.
    Review: First Impressions: Cirrus Cycles BodyFloat Seatpost – GRAVELBIKE
    Buy here: https://shop.cirruscycles.com/collec...float-seatpost
    This is the best suspension seatpost ever made in the history of the world:SR SUNTOUR-bodyfloat.jpg
Members who have read this thread: 31
