dang! this is purty, like a purty moufh
its that stuff form that felt-ish pad on the inside of the box...rather, gnome box.~gomez~ said:Are those geriatric gnome pubes all over that thing?
Yup, your way is much better....pvd said:very nice, but those do make it difficult to do a 2x2 with vertical dropouts.
here's how I do 2x2: http://www.pvdwiki.com/index.php?title=PVD_Two-by-Two
What's the difference?pvd said:very nice, but those do make it difficult to do a 2x2 with vertical dropouts.
Still don't see it...he's using a cassette hub?fishcreek said:look closely.
well? is the felt made from geriatric gnome pubes or what?ernesto_from_Wisconsin said:its that stuff form that felt-ish pad on the inside of the box...rather, gnome box.
I'd love to hear you're explanation at the emergency room. "I slipped and fell on it nurse....."ernesto_from_Wisconsin said:dang! this is purty, like a purty moufh
That's a nice looking device, but the question is.....does it squeal like a pig?ernesto_from_Wisconsin said:dang! this is purty, like a purty moufh
Are you sure about this? What are the gear ratios? Are they even usable?Mallanaga said:ENO has a matching crank with 2 gears as well, to keep the chain the same length the same, and keep a nice chain line.
You may want to double check your math. Those combo's do not work with vertical dropouts.SoloRider said:
Aah, vertical drops, no tensioner, missed your first post. Minimal adjustment on any normal SS without needing two chains. How much need is there for 2x2 on non-SS frames anyway? For example your 2x2 wiki bike would work just fine w/ an ENO Dos setup.pvd said:You may want to double check your math. Those combo's do not work with vertical dropouts.
see: http://www.pvdwiki.com/index.php?title=Chain_Length_Calculation
but then i would need tools to change gears. this is my point, I only need to use my QR to change gears. I do not need to change axle positions. you cannot do this with the DOS product.SoloRider said:For example your 2x2 wiki bike would work just fine w/ an ENO Dos setup.
I don't run 2x2 and don't think I ever will, but I never find myself without tools and since it takes me less than a minute to reset chain tension, I still don't see the need. Also, 30x19 seems a bit insane as a SS gear to me(not that I'm really into the ENO Dos gear choices either), but if it works for you than that's fine.pvd said:but then i would need tools to change gears. this is my point, I only need to use my QR to change gears. I do not need to change axle positions. you cannot do this with the DOS product.
pvd said:Those eccentric hubs are a total joke. They remind me of the 'isolator Hubs' of the early ninties. ha ha. quote]
Elaborate. I've had one since they came out and it is just now needing new berrings and has worked flawlessly. It gives folks the opertunity to turn a conventional frame w/ vertical dropouts into a ss without using a tensioner. The only flaw is that it changes the frames pitch slightly, but never to a point that it affects how I ride. Thats a very minor thing compared to what you get out of it. And "Isolator" hubs we're nothing of the sort.
And I would have never gotton into an activity that involved a little "having to make adjustments" every once and a while. I mean you spend hours upon days trying to perfect some new widget, but seem to have an issue spending 30 seconds making a minor adjustment.
If the only real difference is QR versus bolt on...you can put the DOS freewheel on a QR thread-on SS hub and change gears without tools. Assuming a frame with sliding dropouts like the one you have pictured, or an EBB. Then the DOS ENO set-up works just fine on the trail...without tools.pvd said:but then i would need tools to change gears. this is my point, I only need to use my QR to change gears. I do not need to change axle positions. you cannot do this with the DOS product.
