Results 1 to 2 of 2
Thread: BB questions
    Jun 2005
    BB questions
    hey all, i just had a quick question about BB size for SS. i'm building up an old Specialized Hardrock into a SS machine. i have a UN52 BB that is 107 m in length. i put it in the bike and found that it is way to small. the chainrings and crank arms don't clear the chainstays. i was wondering if anyone has an info abotu what size is best to use to provide the proper clearance.
    thanks.
    nachos rule!
    totally depends on your crankset.
    since you're already got a bb you're halfway there. install your crankset on the 107, then measure from the centerline of your chainring to the center on the seat tube. now compute how far from the bikes centerline your rear cog sits. figure out the delta between those two numbers and it's pretty easy to figure out what length bb spindle you need.
    good luck.
    plus a change, plus c'est la m'me chose - alphonse karr
  1. Crank stiffness question...
    By TheSingleGuy in forum Singlespeed
    Last Post: 02-07-2005, 04:54 PM
  2. Busted crankset Need new parts please help.
    By crux in forum Singlespeed
    Last Post: 10-09-2004, 08:30 AM
  3. Lightweight, durable ISIS BB?
    By 1speed_Mike in forum Weight Weenies
    Last Post: 09-01-2004, 01:07 PM
  4. What's your preferred BB drop?
    By anden in forum 29er Bikes
    Last Post: 06-17-2004, 06:41 AM
  5. I'z got a BB thang goin on...
    By jrm in forum Passion
    Last Post: 04-22-2004, 08:56 AM
