Results 1 to 8 of 8
    New question here. atomlab disk adapter
    is there anywhere to get these online can't find them anywhere
    Retro Grouch
    Reputation: aka brad's Avatar
    Caution;  Merge;  Workers Ahead! I've got one I don't need..
    Quote Originally Posted by boyfromthelak
    I used it for a while on a Surly hub and eventually bought a disc hub. I modified it a bit by filing a rasied area on one side so I could mount it backwards to better positon the rotor. Anyway if you want it it will cost you $5.00 for S&H.
    1G1G, Brad
    Frequent Crasher
    Reputation: SuperBad's Avatar
    For other people looking for these... I got one from Yodobike www.yodobike.com
    The Top Cap Guy
    Reputation: Fast Freddy's Avatar
    Dang... I was just asking Mellow Cat about that thing.....
    FF
    "If I'm leading, I'm bleeding."
    Reputation: qtip's Avatar
    question about the adaptor
    If I remember right, didn't you have issues with it spinning backward if you had a backward pressure on it...which is expected? Is it too wide to use with a fixed side of a flip flop hub, so you could throw the reverse threaded lockring on preventing backspinning?
    Reputation: itsdoable's Avatar
    Quote Originally Posted by qtip
    I ran one on as Airborne SS - Surly hub for a few years. I had to re-space the axle a bit to make it fit properly. I also had to put a torque arm brace to keep the whole thing from rotating.
    <img src="http://gallery.consumerreview.com/webcrossing/images/AtomLab_disc_adapter.jpg">
    If you try to hop on the rear wheel, the adapter will spin loose. Regular hill holding is OK, but sometimes it'll come loose then - not a biggie unless you like to hop/rock on your rear wheel alot. I tried making it work with a fixie hub, but the adapter is pretty wide, and there is not enough room for the lockring as the rotor & torx screws interfere. Potentially you could drill, tap, and put a set screw into the threads, but then you may as well just get a proper disc hub...
    Cheers,
    Tom
    will i have to do anything to my hub and wheel build if i run one?
    Frequent Crasher
    I am only using the Disc adaptor part for my wheel. I have no experience with the frame adaptor part. I have not had an issue with the adapter unthreading, but I put it on tight with a small bit of blue loctite.
  1. XT disk brake weight
    By TeXe in forum Weight Weenies
    Last Post: 04-06-2004, 06:55 AM
  2. Hitch problem / Bar adapter
    By chupster in forum General Discussion
    Last Post: 03-31-2004, 03:23 PM
  3. how should I straighten my 185mm disk?
    By banksgareth1 in forum General Discussion
    Last Post: 03-28-2004, 09:08 AM
  4. To disk or not to disk, that is the question.
    By pherret in forum General Discussion
    Last Post: 03-25-2004, 12:51 PM
  5. Brake adapter question
    By mr. bojangles in forum Brake Time
    Last Post: 03-04-2004, 10:26 PM
