Results 1 to 13 of 13
    Anyone using Black Sheep Ti Fork?
    I am currently running a Fox 80 on my SS and considering going rigid. I have a steel IF fork on another one of my bikes and I am hoping the Ti would be a little more forgiving...somewhere in between the Fox and the IF.
    Am I expecting to much? Will I notice a considerable difference from the steel fork?
    Would realy appreciate some input before dropping $450.
    Cheers
    -Chris
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by NJ YetiMan
    Cheers
    -Chris
    I've never used an IF rigid fork, but I have used a couple of Kellys, a Kona, a Waltworks, On-One, Tange, Kinesis, and a few others. One of my bikes has the Black Sheep now, and it is the best, but the Waltworks feels really good also. I could swing either way, but the BS matches my bike better
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    brg
    brg is offline
    Reputation: brg's Avatar
    Sep 2004
    I'm riding a BS ti fork
    got my BS around a month ago.
    first i didn't like the rigid thing so much - but i was running 1.95 Epicwolfs w/ 45psi. (i'm 4'10" & weigh 105lbs). Now I'm running 2.3 tires with 30psi and it's GREAT. I set a PR on a descent of a local trail on Tuesday and my PR was on my full squishy.
    Quote Originally Posted by Drevil
    oh my! that's a nice bike. where did you get those grips and saddle??
    Quote Originally Posted by brg
    You can get both of 'em from QBP.
    used to be uno-speedo....
    Reputation: dirtdrop's Avatar
    I have one and have only ridden it once so far!
    The ti fork is a unique ride. I'm not sure if its down to the ti stem, ti handlebar AND the ti fork combination or just the ti fork....but its a pretty plush ride for a rigid fork. And thats with running a 2.1 tire at 40psi! I'm going to slap on a bigger volume tire and a little less psi and see how much more comfortable it can get?! I've ridden a steel Surly 1x1 fork and a Pace RC31 fork and both are not as comfortable as the BS fork. But those two forks were being run with a different combination of stem/handlbars so its not a direct, fair comparison. But initial impressions are, yes, a very nice ride!
    Reputation: azjonboy's Avatar
    I also have a BS Ti fork. The same as uno-speedo. I've been riding a Reba the last month. Rode the rigid for the first time today and I was pleasantly surpised. It's not plush like a suspension fork, but it was a lot better than I expected. It's also a nice feeling not to lose energy when climbing out of the saddle. It handled trail chatter very well. Flex was minimal, just enough to take the edge off. I rode Mormon trail ( very rocky terrain ) today and was pleased.
    If you're lucky enough to be in the mountains,
    you're lucky enough.
    Now with 20% more fat!!
    Reputation: JSD303's Avatar
    I'm very happy with my BS Ti Fork. I'm sure James can build you whatever type of fork you want - he's the master!
    It's unanimous.....sheep rule!
    Spoke with James...great guy..but now more questons.
    Are you guys riding the lighter or heavier guage fork? I am incline to go lighter for a bit more flex, but at almost 200 lbs not sure that is smart.
    Also, thoughts on crown hieght. Seems like that may play as much a role in "shock absorbtion" as the thickness of the ti.
    thoughts?
    Mine's the heavier gauge. Same size as the chain stays. I'm 185 and ride aggressively, so I wanted a slightly stouter fork. It weighs just under a pound and a half. It's plenty stiff but still takes alot of the edge off sharp hits. I ride lots of rocky, technical stuff, so that was a must. I didn't want too much flex because I like steering precision. This fork delivers both.
    Just tell James what you want and how it should ride, he'll make it the way it needs to be.
    BTW - James goes 190#. He can relate.
    Reputation: emwarble's Avatar
    I have one on the way for my SIR 9, I will post report when it arrives.
    SyT
    SyT is offline
    Does anyone fab a segmented Ti fork?? (not including that sibex nightmare)
    Reputation: bikeny's Avatar
    Quote Originally Posted by SyT
    Blacksheep makes both unicrown and segmented versions. I believe they are the same price.
    Mark
    I'm riding the thinner guage fork. I think it weighed 692g without a cut steerer tube (10 inches). I weigh 170lbs and am not aggressive.
