Results 1 to 7 of 7
    os2
    os2 is offline
    Anyone running no rear brake off road?
    I'm just building up a singlespeed mtb with disc mounts but no canti mounts. Since I'm thinking I'd like to go with a flip flop hub to have both fixed and freewheel options, that probably means i'd have no rear brake though. Nevertheless, with a disc on the front, i figure it should be OK, but thought I'd ask to hear anyone else's thoughts or experience. thanks everyone.
    i worship Mr T
    Reputation: *rt*'s Avatar
    Quote Originally Posted by os2
    sounds like a recipe for a broken collarbone to me but i happen to be a big fan of brakes and my opinion may be in the minority.
    i guess if you feel confident that you can control and feather the front brake sufficiently so that you will not constantly find yourself flying OTB, and you are riding terrain that doesn't require killer braking power, then just a front brake would be fine.
    rt
    "where are you not going so fast?" (question asked to cyclist on a trainer)
    *rt*'s fabulous blog
    mm blogging
    jl
    jl is offline
    climb
    Reputation: jl's Avatar
    Only the fixed gear fanatics...
    We don't need more to be thankful for; we just need to be more thankful.
    Reputation: itsdoable's Avatar
    I've run fixie off road with no rear brake since I started a few years ago, no problems. You legs are one of the best anti-lock brakes around (until you throw the chain, that is...). I also run a disc up front.
    I'd definitely use a rear brake on SS though.
    Cheers,
    Tom
    hispanic mechanic
    Reputation: sslos's Avatar
    Ditto...
    Quote Originally Posted by itsdoable
    I'd definitely use on rear brake on SS though.
    Cheers,
    Tom
    Only been riding fixed off road for a bit under a year, but front brake only works fine. Again, I wouldn't just use the front with a freewheel, though.
    the los
    Whiskey is my yoga.
    dongerparty.com
    Reputation: firefox's Avatar
    Sep 2004
    Quote Originally Posted by *rt*
    rt
    Only an issue if you ride with a freewheel. If you ride fixed you will not need or want a rear brake. If you ride free, then you will want a rear brake.
    (ff)
    Reputation: pacman's Avatar
    I did, once. On a night ride my rear wheel loosened and on a climb it flew out of the drops and the frame plowed into the ground. Putting it all back together I was missing an Avid pad. Continuing the climb was no problem although my right hand grabbed air a few times. Coming down was at a decent speed was OK because I know the trail and the switchback riding would make IMBA smile, no rear wheel dragging. The one close call was when a riding partner pulled over for someone and I had to climb the berm. I can't recommend one brake riding, if the front brake failed then what?
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. Shimano road brake cable recall.
    By Axe in forum General Discussion
    Last Post: 01-25-2005, 01:40 PM
  3. Shimano road brake cable recall.
    By Axe in forum Brake Time
    Last Post: 01-25-2005, 12:55 PM
  4. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  5. Using rear brake too much?
    By keen in forum Brake Time
    Last Post: 03-22-2004, 12:27 PM
