from a DirtRag 2001 article about disc brakes.....
Dirt Rag Articles
isc Brake Tech Feature by Several Industry Insiders Aug 2001
Q: Joe cross-country trail rider is wondering if he should switch to disc brakes, or are his V brakes all that he needs?
Disc pros:
Keith Bontrager, Bontrager Components: "They are less likely to cause
problems in wet and muddy conditions. There is less wear and tear on rim surfaces
due to abrasion from the brake pads. The rims can wobble a bit and not stop you.
They can be very powerful."
Chris DiStefano, Shimano: "Discs just look cool. OK, OK, I really do appreciate
the performance benefits as well. Greater power, less input force at the handlebar,
increased pad durability, the rim only serves one function: holding the tire. Did I
mention that they look cool?"
Jeff Guerrero, Dirt Rag: "There is practically no difference in disc brake
performance when riding in adverse conditions (snow, rain, mud, cold). The
stopping power is great, even with cheap models of disc brakes. The amount of
effort exerted on the brake levers is less with disc brakes than most V brakes, and
the control is greater due to a greater degree of modulation."
Maurice Tierney, Dirt Rag: "Strong consistent power in all conditions allows you to
go faster and bail out of trouble later."
Ted Wojcik, Wojcik Custom Bicycles: "Improved wet weather braking. Cool
factor."
Disc cons:
Keith Bontrager: "They can be hard to set up in back, especially if your frame isn't
designed for them. In fact, if your frame isn't designed for discs, I'd say don't mess
with them. Changing/evolving standards can make a brake obsolete before it is very
old. They are heavy (or the rest of the things you need to install them are). They are
expensive. They can be finicky. They are tricky to fix on the trail."
Chris DiStefano: "Depending on the choices made-heavier, possible noise
(particularly with frame/fork mounts that vibrate under braking forces)."
Jeff Guerrero: "You need disc hubs matched to a wheel built (specific tension &
dish) to withstand the forces exerted on the spokes. You also need disc brake
mounts on your fork lowers and seat stays. Setup of disc brakes can often be a
chore. Caliper adjustment is done by a variety of means, ranging from washers and
shims to internal micro adjusters and pad modification. Trial and error is the general
method for adjustment, and may be time consuming. Some disc brakes require
mounting adapters. Hydraulic disc brakes often require setup including 'bleeding'
which requires knowledge, caution and some skill. If a hydraulic line breaks, trailside
repair may be difficult if not impossible. Disc brakes are generally more expensive
than V brakes and are considered fairly heavy."
Maurice Tierney: "Weight, hydraulic leaks, incompatibility, new technology has not
quite stabilized."
Ted Wojcik: "Added expense, added weight, added complexity that may be
beyond regular rider maintenance. Bent rotor requires carrying bike out of the
woods. Extreme amount of asymmetrical stress on frame and forks. Disc specific
rims are recommended."
Q: What is the best reason for converting to disc brakes?
Keith Bontrager: "You ride in foul weather a lot and wear through the sidewalls on
rims or wear out brake pads constantly. You do epic rides in the Alps and melt pads
and blow tubes on descents."
Chris DiStefano: "Because you choose to, not for any other reason."
Jeff Guerrero: "Optimum braking performance in all conditions."
Maurice Tierney: "Go faster, stop faster, in all conditions."
Ted Wojcik: "Excess amount of money hanging around. If riding in extremely wet
conditions, braking is usually improved."
Q: What is the best reason for not converting to disc brakes?
Keith Bontrager: "You don't need them to do most riding fast and under control."
Jeff Guerrero: "V brakes are a proven technology and will suffice, especially if the
rider is weight or dollar conscious."
Maurice Tierney: "Cost, weight, technology too high."
Ted Wojcik: "For the most part rim brakes are lighter, simpler, less costly, can be
easily released if a rim is bent."
Q: Provide a brief commentary on the following disc brake options:
Cable versus hydraulic.
Keith Bontrager: "I am only familiar with the basic XC cable and hydraulic. The
cable versions I have ridden seemed better to me. Part of that is due to the similarity
between the 'feel' of the cable brakes and V brakes, which I generally ride."
Chris DiStefano, Shimano: "Cable is great because you've already got the
levers! I really prefer hydraulic over cable, but that's the best quote I could come up
with. Low maintenance and high power with low input force is a superior system. I
can say that better brakes make for a better rider. It worked for me."
Jeff Guerrero: "Cable brakes are very simple to set up and maintain, but are
somewhat less responsiveness and seem to have less overall power than hydraulic.
Hydraulic seems to offer more responsive braking, though set up is often more
involved and maintenance may be a chore."
Maurice Tierney: "Hydro works best because it stays clean, but may leak. Cables
stretch and don't stay clean, but are simpler technology (won't leak)."
Ted Wojcik: "No leaks with cable brakes, hydraulic are smoother and usually more
powerful."
DOT fluid versus mineral oil.
Keith Bontrager: "Cable." (Ed note: Keith likes cable.) Mineral oil, from a toxicity
point of view. I haven't ridden a set up that used DOT fluid."
Chris DiStefano: "Mineral oil is much more friendly to shifters and other bike parts
if spilled. And, oh yeah, earth too."
Jeff Guerrero: "I'm thinking mineral oil may be more eco-friendly."
Ted Wojcik: "DOT fluid is easy to find, but can ruin paint if it leaks. Mineral oil is
much easier on the environment."
Two versus four piston.
Keith Bontrager: "Cable." (Ed note: Keith really likes cable.) Probably two for me.
Four can be trouble to set up."
Chris DiStefano: "But these go to eleven. Seriously though, this is a tough choice. I
enjoy both and have found both to work well for my riding."
Jeff Guerrero: "Some of the top manufacturers stick with two piston, perhaps
because simplicity equals longevity by way of less moving parts to break."
Ted Wojcik: "Four piston brakes are more powerful, but sometimes they require
the pads to run much closer to the disc."
Open versus closed hydraulics.
Keith Bontrager: "Cable." (Ed note: Ok, ok, we get it.) "No opinion really."
Ted Wojcik: "Closed systems can be a nightmare to bleed if the system is opened
for some reason."
Q: Anything else you'd like to add?
Chris DiStefano: "I predict that discs will soon be standard equipment on mountain
bikes. (Cable actuated discs, that is. With hydraulic only at the high end). Don't think
that cyclocross bikes aren't far behind either!"
Jeff Guerrero: "Disc brakes make your bike look cool."
Ted Wojcik: "If we had had disc brakes for a long time, and someone brought
linear pull brakes to the market, we would think that the linear pull design was done
by a genius." For the most part rim brakes are lighter, simpler, less costly, can be
easily released if a rim is bent." (Ed note: V brakes are linear pull.)
