Results 1 to 5 of 5
Thread: 6er, 9er Ratio
    Reputation: Dms1818's Avatar
    6er, 9er Ratio
    My current ride is 26er SS 34:16 ratio. I am about to build a SS 29er. Should I drop my ratio to keep the gear inches the same? I would go from 55 G.I. (26er) to 57 G.I. (29er).
    Would the +2 gear inches matter considering you can roll over more terrain with a 29er?
    Reputation: boomn's Avatar
    This page is a big help. I would want to start with an equivalent of a familiar ratio
    EDIT: added link
    I'm sure many will disagree, but I would re-gear with a slightly smaller ratio. Say 52 gear inches. It takes more effort to spin up the bigger wheels, and the power you can generate is transferred to the ground via a longer moment arm... so a ratio that generates proportionately more torque would be a good thing.
    Haha, i forgot the link in my first post. Here it is
    Quote Originally Posted by sunset1123
    You do have a good point. Taller gears do work better with 29" vs 26" wheels. My original suggestion was because a harder gear can be a frustrating adjustment for some trails, and I wouldn't want that to get in the way of enjoying the new bike experience
