Results 1 to 6 of 6
    Nov 2015
    38t NW Chainring on an 11-36t Cassette
    Bike Newbie here...
    I have a Raceface 38t NW chainring in which I plan to install together with an 11-36t cassette. I was just wondering if this is possible. Our LBS mechanic told me if I install such chainring, it would affect the chain line and makes shifting not smooth. I am currently running a 1x10 setup with a 32t chainring upfront. MY cranks btw is an SLX. BCD is not a problem here. Please enlighten me on this fellow cyclists.
    this is the last place you want to be posting this man....its the single speed forum (no gears).
    your lbs mechanic is a dummy...thousands of people are doing it.
    Jan 2011
    Quote Originally Posted by hotmyk View Post
    I have a Raceface 38t NW chainring....
    Keep the 38 ring and pair it with an Endless cog. For most conditions a 38/22 setup will run nice. Ebay the cassettes but if your 32 tooth ring is narrow wide or single speed friendly you should keep it so you have other options as you collect cogs and rings.
    Nov 2015
    Thanks for the heads up guys. It is worth the enlightenment. Now, I got my hopes high for the setup. I will approach another mechanic from another LBS to have it installed. I will keep my extra one for more options. BTW, sorry for posting in the wrong forum but nevertheless, you both were a big help.
    MaxTheCyclist.com
    Reputation: mdilthey's Avatar
    Dec 2014
    I ran this exact combo for months with no issues:
    Blog Post
    May 2014
    Your LBS is full of ****. I ran a similar setup for a while. Shifted damn good!
  1. Chainring-hub-cassette swap question
    By chuck80442 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-09-2015, 02:21 PM
  2. Replace chainring and cassette?
    By Mobz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-20-2014, 08:44 AM
  3. picking chainring and cassette sizes for a 1x9
    By bryan.gurc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-24-2013, 05:53 PM
  4. Can I Use a 42-32-22 3X8 Chainring W/a 9 Speed Cassette?
    By XCSKIBUM in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-29-2011, 03:30 PM
  5. 11-32 cassette and Chainring Combo
    By danvar in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-28-2011, 05:23 PM
