Results 1 to 13 of 13
    33t x 21t vs. 32t x 20t
    Would I notice much of a difference by switching from a 33 x 21 to a 32 x 20?
    Ovaries on the Outside
    Reputation: umarth's Avatar
    No.
    Out spokin'
    Dec 1999
    Quote Originally Posted by umarth
    No.
    It pains me to say this, but he's right.
    --sParty
    disciplesofdirt.org
    --sParty
    So basically, I can save my money and not mess with my gearing. I do not mind that at all, thanks!
    Reputation: bikeny's Avatar
    I disagree with you guys. 1.57 versus 1.6 ratio. I'll bet you can feel the difference. Will it make a big difference on your ride? Probably not.
    Mtbr Forum Sponsor - Homebrewed Components
    yea, it's about 2 teeth in the front vs 1 tooth in the back. Not exactly, but close (although the bigger the cog in the back, the less this is true).
    both umarth and sparty were wrong!
    Out spokin'
    Dec 1999
    Quote Originally Posted by ISuckAtRiding
    There's a first time for everything.
    --sParty
    disciplesofdirt.org
    Quote Originally Posted by S:Drive
    No, he will not notice much of a difference.
    Quote Originally Posted by ISAR
    Going from 33 to 32 is only one tooth.
    Does this mean I keep my streak of always being right alive?
    yea, but he's jumping one in the back.
    34-21 is closer to a 32-20 than a 33-21 is.
    Out spokin'
    Dec 1999
    You yourself said the increase in front teeth nearly cancels the increase in back teeth. And you're right. Net change one chainring tooth -- virtually "nearly" not much.
    --sParty
    disciplesofdirt.org
    You, yourself said the increase in the front nearly cancels the increase in the back. Net change one chainring tooth -- virtually "nearly."
    --sParty
    no i didnt, i was agreeing with bikeny. i said two teeth in the front is about equal to 1 in the rear. (kinda like two in the pink, one in the stink. thats how i remember it!)
    He was going from a 32t to a 33t with 1 tooth difference in the rear. A 34t-21 instead of a 33t-21 would be closer to the 32t-20.
    Ok, I think we're all square now. I think the initial way you wrote it was a little confusing, but I do absolutely agree with you now.
    I punched the numbers before I responded and I still think the OP is not going notice much of a difference.
    Out spokin'
    Dec 1999
    I said, "virtually nearly not much."
    That's my story and I'm stickin' to it.
    --sParty
    disciplesofdirt.org
