Results 1 to 11 of 11
    I like rigid MTB.
    Reputation: edle's Avatar
    32T - 20T in 29er = 32T - XX? in 26er . Thanks.....
    Thanks.....
    Reputation: J.B. Weld's Avatar
    18t
    Reputation: 4nbstd's Avatar
    32/20 = 1.6
    29" = 73.66cm
    73.66 * 3.14 = 231.30 cm = Distance covered by 1 rotation of 29" wheel
    231.30 cm * 1.6 = 370.08 cm = Distance covered by 1 rotation of 32/20 crankset on 29" wheel
    To cover 370.08cm per 1 rotation of crankset on 26" wheel
    26" = 66.04 cm
    66.04 * 3.14 = 207.37 cm = Distance covered by 1 rotation of 26" wheel
    370.08 / 207.37 = 1.78 = Gear ratio required on 26" to cover the same distance as 32/20 on 29"
    32 / 1.78 = 17.98 = 18 = Rear gear to achieve 1.78 gear ratio with 32t chain ring.
    Ghisallo Wheels
    I'm really good looking.
    Reputation: jetboy23's Avatar
    I actually like using the gain ratio as it seems to take crank arm length into account. This, seems to me, is a better scale of the power it will take to turn the pedals over. I use Mike Sherman's page which will give many other calculations as well. Mike Sherman's Bicycle Gear Calculator
    Quick and fast rule when addressing the gear range most SSers will use is about a tooth in the rear per wheel size. 26 to 650b= +1t, 26 to 29er= +2t, 29er to 650b= -1t, etc. And, 2t up front is similar to 1t in the rear. Confusing yet?
    Reputation: disgustipated's Avatar
    MATH IS FUN!
    Ring Tooth count X Wheel Diameter
    Divided by
    Cog tooth count
    Magic gear inch calculonomy
    Calmer'n you are.
    Reputation: irideiam's Avatar
    Dec 2011
    Here's the calculator I use, you can load it on your PC or run it from the web:
    Rabbit, a singlespeed and fixed-gear cycling calculator
    Klunk on............
    I like rigid MTB.
    Thanks for the inputs.
    Your guys are good in Math.
    May 2005
    Quote Originally Posted by 4nbstd View Post
    32/20 = 1.6
    29" = 73.66cm
    26" = 66.04 cm
    You way over did that since everything cancels out except the difference in the wheel diameters. It's actually much simpler:
    559/622 = 0.90
    Comparing bead seat diameter of 26 inch to 29 inch for more accuracy since 26 and 29 are nominal measurements. Assumptions: tires are the same size and aspect ratio, chainring is the same size.
    0.90 x 20 = 18
    Quote Originally Posted by Thor29 View Post
    559/622 = 0.90
    0.90 x 20 = 18
    Ya, but your answer will only get partial mark. You have to show your work for full mark.
    Ghisallo Wheels
  1. Has anyone gone from 26er to 29er and back to 26er?
    By grendelos in forum Colorado - Front Range
    Last Post: 11-22-2012, 08:21 AM
  2. SS 29er or 26er? Help!
    By orangedotz in forum Singlespeed
    Last Post: 08-11-2012, 12:22 PM
  3. 29er/26er
    By dmassey in forum General Discussion
    Last Post: 04-18-2012, 09:09 AM
  4. 26er or 29er?
    By Sdaniels in forum Bike and Frame discussion
    Last Post: 10-31-2011, 10:25 AM
  5. 26er vs 29er
    By 1SPD in forum Beginner's Corner
    Last Post: 03-08-2011, 01:57 PM
