Results 1 to 12 of 12
    holy schfincter..
    Reputation: TigerRider's Avatar
    New question here. 29er Vertical Sliding Dropout Frames
    Anyone have a list of manufacterers that make a 29er SS sliding vertical dropout frames? Thanks! So far i am looking at Lynskey Ridgeline or possibly some cheaper steel options.
    openwound
    Reputation: voodoochild's Avatar
    Do you mean horizontal? I'm having a little difficulty visualizing a sliding vertical dropout...
    holy schfincter..
    Jan 2009
    Immediately voodoo comes to mind, I know they have a Ti 29er offering that has sliding dropouts, they are also slated to start production on a 29er bokor which if they follow their normal recipe it should have sliding dropouts as well.
    Here are some other options that come to mind quickly:
    Lynskey ridgeline
    gunnar ruffian
    I do also know of another company who does work with steel frames that is in the beta phases of their own 29ers with sliding dropouts that I would expect to start becoming available in short order. I don't think they have announced it yet so I won't mention specifics. If you can hang tight I would expect more and more companies to incorporate a similar tensioning style or at least most coming with EBB's
    Reputation: mitzikatzi's Avatar
    Lynskey ridgeline
    gunnar ruffian
    2010 Kona Unit
    Redline Monocog Flight
    Reputation: masterofnone's Avatar
    Kona makes dropouts just like that voodoo on a lot of their models.
    Sorry, I don't know what that frame is, but it's the same exact design.
    nicknamed "paragon sliders".
    LOADS of companies do them, any custom maker, and kona, voodoos, specialized has a version of them (or did?) several companies are now moving to swinging dropouts ("black cat" style)
    If steel is real then aluminium is supercallafragiliniun!
    The Ti frame pictures is a Lynskey. The sliding dropouts are called "Paragon Dropouts", because they are manufactured and distributed by Paragon Machine Works (with all due respect to Ground Up designs . . . .). Kona, for one, has a sliding dropout, but it is not a Paragon dropout.
    Thanks to www.weavercycleworks.com for my awesome bike frames!
    @adelorenzo
    Reputation: anthony.delorenzo's Avatar
    Misfit Psycles DiSSent.
    The steel Salsa El Mariachi will have a swinging dropout design, should be available real soon.
    Cheaper than ti handmade in steel are the Siren John Henry, Curtlo, Misfit Cycles FE, and Curtlo. For a little bit more but still less than Ti is a Waltworks. Prices start to go up from there with custom frames, but like mentioned above, almost any custom builder can build you a frame with the paragon dropouts.
