    Feb 2006
    2008 Kona Kula 29er
    I am looking to convert my bike into a light, fast single speed commuter. I live in Manitoba, which is extremely flat and has long winters (will commute in winter). My commute is 8 miles each way and has literally, 5m grade change over that span.
    I was considering buying the 2013 Kona Unit, but figured I could spend less and get more if I just converted my existing bike. Here is the bike (only upgrade are Stans Arches bought earlier this year).
    KONA BIKES - 2008 BIKES
    I have money to spend, but don't want to spend a ton. I am looking for a new rigid fork (carbon perhaps). New crankset if needed and of course the rear conversion kit.
    Any thoughts or help would be appreciated. Thanks
    NedwannaB
    Reputation: JMac47's Avatar
    Convert it!
    Quote Originally Posted by Mad Dingo View Post
    I had one and you can't build up a much lighter alum frame bike then that one.
    Parts you'll need:
    -Should be able to get a 104bcd pattern "non ramped" single front ring that will fit spider arms of that crank $15-80 (US) depending on the bling factor you're looking for. And with a bashring you should be able to use same bolts too. Just need to get new shorter bolts if you don't use a bashring.
    -Any one of the SS spacer kits for your rr hub. I used Origin 8. ~$30
    -Inexpensive/blingy rr steel/alum/Titanium cogs ~$10-70
    -Your sliding rr dropouts are already set for the conversion. Snip your chain to fit or buy new ~$15.
    -A black Niner Carbon fork will be sweeet on that thing
    Good luck!
    Wait whuuut, who did he tell you that!?!?....
    Feb 2006
    Thanks. I have the tools, but will need the luck. I hit the LBS on the way home and they set me up.
    - DMR SS Kit 16t
    - SS Chain Ring Blots
    - I am just replacing my front Chainring with a new 44t FSA ring. (For the time being). Ultra Flat where I live. Bike mainly for commuting.
    - New chain. SRAM 8 speed chain.
    - 6 Pack Granville Island Hefewiezen
    - 6 Pack Granville Island Maple Cream
    Once I have it setup and find that I like it, I will replace the fork and maybe some other components. This setup will give me a nice introduction.
    I looked at that Niner carbon...... dreams
    Feb 2006
    Thanks for your input JMac. Here is the almost final result. New forks and tires next.
